585,975 active members*
4,612 visitors online*
    Aug 2019
    8
    PC does not detect CNC machine when connected
    Hello,
    I have recently received my CNC Router machine from OMNI. I have connected the machine to my PC via USB cable and the computer/mach3 does not detect it. Zach from OMNI told me there is no need to download a driver or plugin and basically tells me that I should be able to simply plug and play without any drivers or configuration. I'm not sure if it matters but I am running Windows 10. If anyone can assist me it would be greatly appreciated.
    Thank you.
    Aug 2019
    8
    Re: PC does not detect CNC machine when connected
    I was able to find the correct driver and got my machine running on all axes so I no longer need assistance with this issue. I do have another question though if anyone can give it some consideration. I'm unable to control the spindle/VFD through Mach3. The VFD is on and displays info on the screen but it doesn't seem to display RPM or control the spindle. I can provide pictures and/or additional information if it helps. Thanks.
    Aug 2009
    230
    Some VFDs have a parameter setting that selects where they get their commands from - front panel; MODBUS, external potentiometer, relay contacts, and/or 0-10v input.
    Look in your owners manual for the VFD to find this. If the machine did not come with the VFD manual; you may be able to find it online by googling for the VFD's manufacturer and model number.
    Sep 2020
    Quote Originally Posted by JaMRH View Post
    I am a new member, AldoV from Belgium and I have the same problem you had, I bought a sainsmart Genmitsu 3018MX3 and when I connect it to my PC with Windows 10, it is not recognised. In device manager I see only COM1 available and that does not connect to my CNC.
    I see above that you found a driver that works, could you possibly let me know wich one it is?
    Thanks, AldoV
    Hello,
    Thank you.
    Hello Sir, i am having the same issues, can you help please?
  1. external devices connected to a CNC machine
    By sinha_nsit in forum Fanuc
    Last Post: 01-02-2024, 10:21 PM
  2. Networking my laptop & desktop connected to CAD machine
    By nMorgan in forum Computers / Desktops / Networking
    Last Post: 02-05-2019, 06:34 PM
  3. Everyone's support for fiber laser cutting machine to detect the future
    By jackmiao in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-28-2018, 02:40 AM
  4. Compumotor X language to detect machine stop?
    By greif in forum Stepper Motors / Drives
    Last Post: 01-23-2014, 11:07 PM
  5. Can the PC be connected to the host of Steeltailor CNC cutting machine?
    By Steel Tailor in forum Other Machine Topics
    Last Post: 12-16-2013, 09:17 AM
