585,762 active members*
4,086 visitors online*
    Sep 2019
    8
    Help with dual Y axis drives
    I bought a machine running on Mach3, and it has 2 Y axis drives, that are just daisy chained together off of the breakout board. As far as software is concerned there is only 1 drive. This makes it hard to square the gantry. I would just set it up as a slave drive, but its already a 5 axis machine, and the breakout board doesn't have room for another drive. So I'm trying to find a breakout board that can run 6 drives, plus a VFD spindle. I haven't been able to find out how to do this. Everything seems to be limited to 5 axis if it has VFD control built in. Any help with this would be greatly appreciated.
    Re: Help with dual Y axis drives
    If you're using a parallel port, there aren't enough outputs for 6 axis and a VFD. But you could add a second port and another breakout board.
    Or go with something like an ESS with an MB3 breakout board, or a UC300ETH with a UB1 breakout board.
    Sep 2019
    8
    I'm currently using a UC100 to run my one board. Can I use another one to add a second board? or can I not run 2 of them at once?
    No, only one UC100.
  1. Dual stepper drives?
    By grizzlymog in forum Torchmate
    Last Post: 02-19-2017, 08:32 PM
  2. Compensating for differences in lead/ballscrews in dual drives axis?
    By bebob1 in forum DIY CNC Router Table Machines
    Last Post: 08-13-2012, 03:43 AM
  3. A Dreadful Likelihood of Dual Chain (or belt) Drives
    By Beefy in forum Waterjet General Topics
    Last Post: 01-12-2011, 03:49 PM
  4. G540 and 4 axis w/ dual X drives
    By dsnellen in forum Gecko Drives
    Last Post: 07-20-2010, 04:02 PM
  5. Dual Steppers or Timing Belt for Dual X-axis?
    By GEBrown in forum Linear and Rotary Motion
    Last Post: 05-27-2010, 05:45 PM
