585,991 active members*
4,725 visitors online*
Results 1 to 1 of 1
    Sep 2019
    Lightbulb Calcite Grinding Mill
    Calcite is a common calcium carbonate mineral, which is easy to grind its 3 Mohs hardness. It can be used as a raw material in the silicate industry. Generally, the grinding of calcite requires a large grid of finished products, i.e., an extreme grinding fineness is required. Thus, the ultra-fine grinding machine is commonly used for calcite grinding. The calcite ultrafine grinding machine works in a high-efficiency and stable way and has a long service life. The FTM calcite ultra-fine mill is a custom and ideal choice.
    The Working Principle of Calcite Grinding Mill
    First Stage: Crushing.
    Large-sized calcite is crushed into small pieces under 40mm by jaw crusher or hammer crusher
    Second Stage: Grinding.
    Crushed calcite pieces are elevated to the store and fed into the grinding body evenly by electric-magnetic vibrating feeder
    Third Stage: Separating.
    Ground powder is separated by the separating system. Disqualified powder is sent back to have another grinding process.
    Fourth Stage: Collecting.
    The qualified powder flows with the air into the collector. Here, the finished product is collected separately and then conveyed out to the end product bin.
    Packaged by the automatic packager, the entire grinding process is realized.
    Applications of Calcite Grinding Machine
    Calcite powder manufacturing machine has a wide range of applications. For example, it can be used in the production of building materials, papermaking, toothpaste, cosmetics, textiles, and other artificial stones, artificial floor tiles, paints, cables, asphalt, and natural rubber in daily chemical products. Synthetic rubber, ink, electrical insulation, etc. In addition, calcite ultra-fine grinder can make calcite powder used as product modification, purifier, detergent in the petroleum industry in mechanical manufacturing, high-temperature superconductivity, aerospace, and other high-tech fields.
    Calcite can be widely used in the following industries after deep processing of grinding machine:
    Calcite deep processing products-heavy calcium fine powder used in artificial stone, artificial floor tile, natural rubber, synthetic rubber, paint, plastic, composite new calcium plastic, cable, paper, toothpaste, cosmetics, glass, medicine, paint, ink, cable, power insulation, food, textile, feed, binder, sealant, asphalt, building materials, linoleum construction products, fire ceiling and daily chemical products as fillers. It can not only reduce the production cost of various industries, but also improve the function and performance of related products, increase the volume of products, and is one of the inorganic filling masterbatches. The insulation strength of the cable can be improved by adding heavy calcium superfine powder to the cable skin, and the car chassis coating made of calcium carbonate superfine powder can make the car chassis have stronger anti-scour ability than the steel plate. It has been widely used in catalytic cracking, molecular sieves, detergents, purifiers, product modification, metal smelting, chemical synthesis, aerospace, high-temperature superconductivity, mechanical manufacturing and so on, especially in high-tech fields. Ultra-fine heavy calcium powder can be used as the basic material for these industrial sectors, so the demand is particularly high. As a result, heavy calcium fine powder has become the upstream and original material of most industrial manufacturing, including almost all the production and manufacturing sectors of light and heavy industry.
    Working Principle of Calcite Mill Grinder
