584,874 active members*
5,364 visitors online*
Results 1 to 3 of 3
Threaded View
    Home/Limit Switch Guidance
    D&M 5 Lathe Acorn CNC retrofit, only replacing the controller and adding DC isolation for the spindle drive.
    Have everything about 75% wired up and just realized that there are no home/limit switches on the machine. Better yet I don't know the first thing about what kinds and where to place them.
    Looking for guidance on what would be the appropriate switched to buy, mechanical or proximity?
    Also where they should be mounted, I would assume they will be at the X+ and Z+ limits but how will this play with the tail stock.
    Any help you can offer or examples from your own projects would be greatly appreciated!
    -Joey
    Attached Thumbnails Attached Thumbnails 20190916_183858.jpg   20190916_183903.jpg   20190916_183908.jpg
  1. MACH 3, Warp9 smooth stepper, Leadshine mx4660 Limit switch home switch woes HELP
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-14-2018, 08:26 PM
  2. Is it possible to use the home switch as the limit switch as well?
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 11-02-2012, 06:25 PM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
