585,712 active members*
4,158 visitors online*
    Feb 2019
    4
    Ima quadroform
    Hello friends.
    My cnc is ima quadroform and the program imawop 2.6 and I don't have dxf module in the machine,How can I post from auto desk 360 fusion or another programm fmc files to imawop 2.6.... Thank you
    Apr 2015
    327
    Re: Ima quadroform
    Hello,
    you need a postprocessor which generate like this.
    N10 ( CONTUR ROUTING )
    M05
    [TNEXT]=99
    [VORPOSX]=-25 [VORPOSY]=20
    T606
    L123=18000
    L128=0 G77 H10
    G41 G00 X-25 Y20 ZL932
    G01 Z-3 F4000
    G03 X-5 Y0 R20
    G01 X0 Y0 F5000
    X0 Y0
    X0 Y0
    X0 Y0
    X5 Y0
    L160=520 (LENGTH)
    L161=108 (WIDTH)
    L162=12 (THICKNESS)
    L929=2 (DATUM SHIFT_X)
    L930=2 (DATUM SHIFT_Y)
    L167=524 (RAW PANEL LENGTH)
    L168=112 (RAW PANEL WIDTH)
    L114=0 (EDGEBANDING ACTIVE)
    L166=0 (MIRROR IMAGING)
    L163=0 (TEMPLATE HEIGHT)
    L164=20 (SAFETY DISTANCE)
    L158=1 ( TISCHCODIERUNG NULL )
    L159=1 ( TISCHCODIERUNG SPIEGEL )
    E10028=0 (UNCLAMP IF PROGRAM ENDS)
    E10006=0 ( UMTRANSPORT )
    E10009=0 (SAW MACH.CENTER LOADING)
    E30005=0 (VARIABLE TAPE REEL MANAGEMENT - PLC)
    E30052=0 (IDENTIFICATION FOR PROGRAMS NOT TESTED)
    E30051=0 (SKIPPED BLOCK IDENTIFICATION)
    G77 H5
    [IMAWOP]=1
    (HORIZONTAL BORING T=431)
    [VORPOSX]=0 [VORPOSY]=61
    T=431
    L10=0
    L103=224.8 L104=899 L112=4 L123=8000
    L116=2
    L11 = 2 ( 0,1, )
    L107=0 L108=61 L119=20 L111=6
    G77 H86
    [VORPOSX]=0 [VORPOSY]=3
    T=431
    L10=0
    L116=2
    L11 = 2 ( 0,1, )
    L107=0 L108=3 L119=20 L111=6
    G77 H86
    T=431
    L10=0
    L116=4
    L11 = 2 ( 0,1, )
    G77 H86
    T431
    L10=0
    L116=4
    L11 = 2 ( 0,1, )
    G77 H86
    M05
    [VORPOSX]=0 [VORPOSY]=15
    T421
    (SAWING)
    T421
    L111=6 L112=0 L121=4
    L107=0 L108=15 L109=520 L110=15
    L102=0 L118=2 L116=0 L126=40 L103=1250 L104=5000 L123=8000
    G77 H91
    (SAWING)
    T421
    L107=0 L108=18.4 L109=520 L110=18.4
    G77 H91
    (SAWING)
    T421
    L107=0 L108=21.8 L109=520 L110=21.8
    G77 H91
    (SAWING)
    T421
    L107=0 L108=23 L109=520 L110=23
    G77 H91
    G42 G0 X260 Y165 ZL932
    G1 Z12.127 F1500
    G1 G42 X260 Y108 F2045.1
    G1 X520 Y108
    G1 X520 Y13
    G1 X485 Y13
    G1 X485 Y0
    G1 X35 Y0
    G1 X35 Y13
    G1 X0 Y13
    G1 X0 Y108
    G1 X260 Y108
    G1 G40 X260 Y165
    G40 G0 ZL932
    N9999 L165=L165+1 G79 L165>1 N10
    L116=1 G77 H6
    I can help you with this,. Let me know.
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Feb 2019
    4
    Re: Ima quadroform
    Thank you very much but where I can find this post prossesor and where can I see if my machine generate that codes?
