586,000 active members*
4,925 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > G31 command stops since moving to Ethernet SmoothStepper
Results 1 to 1 of 1
    Jul 2003
    138
    I have a z-height and center finding macro I have run for many years that make use of the G31 command. They failed when I moved to my ESS and after some trouble shooting I discovered the G31 command is no longer working. Even when entered as a MIDI command noting happens, For example, G31 Z1 F10.
    I have done some searching here and found a few similar observations but without a definitive solution.
    The probe LED does work via the diagnostic page as expected
    Please refer to the image for wiring of my probe port.
    Mach3 versions tested are below and I have also tested from a Dell Laptop and HP Thin client both running Windows 10.
    Mach3 Version R3.043.062
    Mach3 Version R3.043.066
    ESS Version: ESS 2019_02_25 10w2a-10f1
    G31 does not move and axis as a midi command however G32 work just fine.
    Any help would be appreciated... Thx.
  1. Ethernet smoothstepper connected to a USB/C port to ethernet adapter help
    By Ricklee in forum SmoothStepper Motion Control
    Last Post: 03-03-2019, 02:47 PM
  2. Smoothstepper ethernet or Xhc Mk4-v 4axis ethernet?
    By Nleo22 in forum Want To Buy...Need help!
    Last Post: 09-08-2017, 11:37 PM
  3. Want to buy used Ethernet SmoothStepper
    By Azalin in forum Want To Buy...Need help!
    Last Post: 03-28-2016, 09:33 AM
  4. Smoothstepper (ethernet)
    By t300 in forum Novakon
    Last Post: 09-08-2012, 02:43 AM
