585,754 active members*
3,807 visitors online*
    M32 Tool setter not setting correct Z offset
    I have a mazak htc-400 with a m32 plus control. when using the tool probe in semi auto mode it sets the z offest but it is always positive and it doesnt match up to the same value if you handle jog the tool into the tool setter till it beeps. now the difference in the z machine coordinate fluctuates. it isnt a set value that i could just add. for example. T1 set with semi auto mode gave me 6.5565 and the when i handle jogged it into the tool setter i got -13.4856. so i changed the 6.5565 to -6.5565. now the difference between those two are 6.9285. so i touched off another tool to see if the difference was the same cause then i was just going to offset my wpc z offset that amount. But i got a different value once again. how do i fix this or am i doing something wrong? we have alot of tools in this machine that we use on multiple parts and it would be easier to just touch one tool off the part rather than 20 every set up.
    also we are using eia/iso
    Sep 2012
    216
    Re: M32 Tool setter not setting correct Z offset
    Don't quote me on this but I think for tool offsets done in Mazatrol to work in eia there is a parameter that needs to be changed otherwise they aren't recognised.
    Regards Bob
    Quote Originally Posted by sudsy View Post
    The manager prior to me had the parameters changed so he could use eia/iso. But im not sure what parameters were changed.
    Aug 2019
    339
    Can we see your probing macro?
    Those params are normally called by the macro file and having that macro code uploaded here would make it easy'er for everybody to debug remotely
  1. setting up tool setter on seperate input help
    By 1hander in forum Benchtop Machines
    Last Post: 03-12-2017, 05:51 PM
  2. Lynx 300 Tool setter and work offset questions
    By cruizer67 in forum Daewoo/Doosan
    Last Post: 06-06-2016, 07:24 PM
  3. Setting tools on Haas Sl20 without tool setter
    By nigelw in forum Haas Lathes
    Last Post: 01-27-2015, 08:40 PM
  4. Tool Length Offset Tool Setter
    By CNCneeds in forum News Announcements
    Last Post: 01-03-2014, 06:27 PM
  5. Setting up a Tool Setter.
    By Smackre in forum Mach Software (ArtSoft software)
    Last Post: 06-17-2006, 04:41 AM
