585,582 active members*
3,791 visitors online*
Results 1 to 9 of 9
    Aug 2015
    142
    Need help macros probing
    I make an macro based on info found here , but i am having an issue , it is working good when i try to use it when a job was done , or a tool change , but if i stop it in middle , and i want to change tool and probe again , it goes straight thru stock material .
    I need a litte help here with code, because i don't understand why it is working good when i try to probe first time , and it doesnt work in milling process .
    Thanks .
    Jun 2010
    4256
    Re: Need help macros probing
    First of all, to get any help at all you MUST tell us what software you are using!
    Mach3? Mach4? UCCNC? LinuxCNC? Something else?
    It helps know what platform you are running on, and what sort of hardware you have as well.
    Cheers
    Aug 2015
    142
    Thanks , i am using uccnc last version .
    Apr 2014
    59
    Which macro do you want to work with? (The 2 macros you uploaded are not the same.)
    Aug 2015
    142
    First i get tool offset with m31 , and it writes on c axis offset .
    After i want to change a tool , i use only m200 , but the issue is when i try to use it in a middle of a tool breack or a stop , it doesnt go at measuring point , instead it goes straight thru stock .
    If cnc stops for a tool change it works fine .
    I think is something about g90 g91 , but i realy dont know , that i want to ask for somme help .
    Thanks .
    Apr 2014
    59
    I corrected some logical errors, but I'm not by a machine, so I could only test in demo mode. Please, try it and report the results.
    BTW, which last version do you use? (1.2049 stable or 1.2111 development?)
    Attached Files Attached Files
    Aug 2015
    142
    Now i use 1.2109 with uc 400eth .
    Apr 2014
    59
    The 1.21xx series is in development state, so always use the latest of them. It is now the 1.2111 and you can find and follow it here: forum.cncdrive.com • View topic - UCCNC test releases posted in this thread
    Aug 2015
    142
    Thanks , now it works like it should .
  1. Meldas 520 Mighty comet vmc500 Renishaw probing macros??
    By A1CNC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-30-2022, 05:34 PM
  2. My UCCNC probing screen and macros
    By A_Camera in forum UCCNC Control Software
    Last Post: 10-16-2018, 01:03 PM
  3. Replies: 1
    Last Post: 10-10-2017, 07:44 PM
  4. CNC Mastercam X w/ probing macros-Aerospace exp - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:56 PM
  5. probing macros
    By kendo in forum Haas Mills
    Last Post: 06-06-2009, 12:24 PM
