585,931 active members*
4,407 visitors online*
IndustryArena Forum > Manufacturing Processes > Drilling > Drilling and tapping with subprogram
Results 1 to 1 of 1
    Apr 2016
    How can I make this works?
    Im driving a Makino a92 with PRO5 and fanuc system.
    What I want to do is to use the same subprogram (positions of the holes) for the drill and tap.
    Example:
    T1=Drill
    T2=Tap
    Each Tool has it own program, bit then I call for the same subp.
    G81G99Z-22....drill cycle
    M98P10
    Next Tool
    S795
    M135
    G84G99Z-12.R5L0... Tapcycle
    M98P10
    The drill has the same depth on all the holes. The tap has different depths. Like first Hole -10 second -5 and so on.
    My subprogram looks like this.
    O0010(L1-L20)
    IF[600EQ0]GOTO1
    GOTO#600
    N1
    #600=1
    X-100.Y25.(L1) this Hole should be z-10 mindepth
    N2
    #600=2
    X-110.Y25.(L2) and this z-5
    and so on.
    Best regards!
