585,956 active members*
4,599 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Can you cut this on a 4th axis??
Results 1 to 7 of 7
    Jul 2010
    180
    This is a 6mm key. Half round and half square. I have the 6mm keyway stock so the challenge is to round the 6mm top. Understand I could do it with a bull nose, but can you do this in a 4th axis rotary?
    Dec 2013
    5717
    Re: Can you cut this on a 4th axis??
    It could be done on a 4th axis, but I would just use a corner rounding cutter.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2019
    339
    I would also do it as Jim suggested.
    4ax zig-zag is also possible although would require a great deal of support/stabilization for that long part. Think custom fixture, and/or additional features like center drilled hole to accommodate a tailstock/live center. By the time you are done your hourly-rate cost +20x the price of the cutter required for that job.
    Just easier to clamp it onto a 3ax vise and running two finish passes with a brand new/sharp R3 corner rounding cutter.
    Jun 2008
    1838
    Quote Originally Posted by FastFarmer View Post
    I agree with all the other posters, such a job would be easiest done with a simple contour and a rounding cutter, just pop it in a vise and a couple of rough and finish passes and job done.
    Yes it can certainly be done in a 4th axis but the fixturing required would take time and money to make.
    However if you are determined to use a 4th axis then have a look at the attached Fusion file I have done and if it is of some use as a pointer then go for it
    JFYI When I opened your file it was 60mm square and 700 mm long, some key that
    Regards
    Rob
    Jul 2010
    180
    Quote Originally Posted by The Engine Guy View Post
    Excellent!! Challenge complete..
    Thanks!
    Jun 2008
    1838
    Thanks!
    Didn`t know it was a challenge, is there a prize ??
    Few of these would do it :cheers:
    Although come to think of it most stuff seems to be a challenge with Fusion 360
    Regards
    Rob
    Jul 2010
    180
    Here ya go... first prize.. lol. Although I think I've convinced myself it's not the way to do it!
    https://youtu.be/wCJ9Fp8QGTc
  1. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  2. Replies: 0
    Last Post: 04-27-2016, 04:08 PM
  3. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  4. Replies: 0
    Last Post: 08-04-2013, 05:30 AM
  5. 5-axis, 4-axis, and 3-axis CNC Router manufacturer
    By roctech in forum Roctech CNC Routers
    Last Post: 05-24-2012, 09:12 AM
