586,009 active members*
4,941 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Can't change travel, Tool Changer values in Parameter Settings
    Dec 2009
    521
    I aquired a 2003 TRM. It had been sitting for quite awhile.
    It lost its parameter settings.
    In haste, I reloaded some defaults so I could jog the Z down to clear a door.
    Now, I wanted to correctly reload the parameter settings.
    First, is there a way to default the control, clear everything to start again?
    The issue is that while I can change axis configuration, (its ok at X, Y, Z) it will not let me in to the field to change the travels, which it defaulted to and are incorrect.
    I can't remove references to ATC and # of tools either, cant change the spindle RPM, RPM Factor etc. Won't let me cursor to those settings.
    Attached are a couple of screen shots.
    I'm out of ideas.
    Thanks in advance.
    Marty
    Oct 2008
    1632
    Re: Can't change travel, Tool Changer values in Parameter Settings
    Make sure they key is installed and turned on, or open the pendant and install a jumper across the switch. I'm not certain that's your problem but mine limits what I can change in setp unless the key is ON.
    Dec 2009
    521
    Quote Originally Posted by rwskinner View Post
    Thanks for the reply. My pendant does not have a key switch. That's not to say there isn't a place in the control cabinet to put the jumper in or slide a switch. That would make sense.
  1. Abort during tool change - tool changer stuck
    By yugami in forum Milltronics
    Last Post: 07-24-2018, 10:37 PM
  2. Replies: 2
    Last Post: 04-12-2016, 01:26 AM
  3. Bridgeport interact 412 tool changer does not slow b4 tool change
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2013, 10:50 PM
  4. Replies: 3
    Last Post: 05-28-2009, 01:16 AM
  5. Help with a Tool Changer Parameter
    By unionswiss in forum CNC Machining Centers
    Last Post: 10-25-2007, 07:42 AM
