585,763 active members*
4,301 visitors online*
Page 1 of 4 123
Results 1 to 20 of 78
    Sep 2019
    197
    Need help please
    Hi, i have been looking at developing a control panel to be used for various types of cnc machines. But i am not sure what people's requirements would be.
    Basically i need to know what people would be looking for when shopping for something like this.
    Although i have no problem building the unit i am unsure what i should include, my own likes/requirements are usually over engineered, thus i would like some input please
    So far i have the following
    1) For now it will be for nema 23 steppers, not looking at servo's system atm
    2) The VFD will be inside the same box as the other components
    3) 230V system only
    4) UCCNC
    5) G540 with an option to add another drive???
    6) Maximun spindle size of 2.2Kw
    Any input will be greatly appreciated cause i just cannot decide on the final setup
    I milled what i thought was the final gland plate today but manage to stuff it up, even forgot the gland hole for spindle cable
    Erick
    Aug 2009
    230
    Re: Need help please
    3) 230V system only
    That significantly limits your market. I'd design it with power supplies that can accept either 120v or 240v 50/60hz; and set up the mounting holes for the VFD to accept several popular VFDs (including the Chinese spindles, some of which require two modules - a 48v SMPS and the VFD itself). Then you could offer several configuration options; but have only one SKU for the panel frame itself.
    4) UCCNC
    I'd add the mounting holes for some other choices as well. Many people like UCCNC; but others are partial to Mach 4. Adding some holes gives you the option of offering both.
    The G540 is a nice module; but some machines may need a bigger drive option. I'd also offer G203V drives.
    You have a bunch of IEC power connections on that panel... why? I can understand power in for the whole system; and perhaps power out for an external PC case... but what are the others for?
    What are the four 4-pin aviation connectors for?
    I would not mount the G540 externally to the case. I would put it inside, next to the motion control card (UCCNC, Mach 4, etc). I would run DB9 jumpers to connectors mounted on the case; where the stepper motor cables would attach. This would keep the connection from the motion control card to the G540 (or G203Vs, etc) internal to the case.
    I would also give serious consideration to mounting the PC inside the main case; perhaps with a MiniITX motherboard.
    Is this just the control electronics; or are you also going to provide a user interface panel (monitor/touchscreen, cycle-start & feed-hold buttons, e-stop, jog wheel, keyboard, etc)?
    Sep 2019
    197
    Britt, thanks for your input /advise
    "That significantly limits your market. I'd design it with power supplies that can accept either 120v or 240v 50/60hz; and set up the mounting holes for the VFD to accept several popular VFDs (including the Chinese spindles, some of which require two modules - a 48v SMPS and the VFD itself). Then you could offer several configuration options; but have only one SKU for the panel frame itself"
    The power supply that i am using does accept 110V, reason why i wanted to limit the supply voltage was due to the fact that the VFD i am supplying with the panel is 240V.
    "I'd add the mounting holes for some other choices as well. Many people like UCCNC; but others are partial to Mach 4. Adding some holes gives you the option of offering both"
    This is not a problem, i have a base that will /could also accept eg the smoothstepper.
    "The G540 is a nice module; but some machines may need a bigger drive option. I'd also offer G203V drives"
    Reason for the g540 is basically space saving, usually i would use leadshine drives.
    "You have a bunch of IEC power connections on that panel... why? I can understand power in for the whole system; and perhaps power out for an external PC case... but what are the others for?"
    The large iec is the power input/filter....the others will be internally switched but externally supplied for mains devices.
    "What are the four 4-pin aviation connectors for?"
    Limits/proxies or any other low voltage equipment, need not be four pin.
    "I would not mount the G540 externally to the case. I would put it inside, next to the motion control card (UCCNC, Mach 4, etc). I would run DB9 jumpers to connectors mounted on the case; where the stepper motor cables would attach. This would keep the connection from the motion control card to the G540 (or G203Vs, etc) internal to the case."
    The connection to the motion controller will be inside reason for the additional 25 pin plug, basically just a loop if required.
    "I would also give serious consideration to mounting the PC inside the main case; perhaps with a MiniITX motherboard."
    Space will be a huge problem if i were to do this??
    "Is this just the control electronics; or are you also going to provide a user interface panel (monitor/touchscreen, cycle-start & feed-hold buttons, e-stop, jog wheel, keyboard, etc)?"
    Control panel, user interface/buttons will be external, reason for all the 4 pin connector
    Sep 2019
    197
    This is exactly the reason for this thread, all the options are driving me up the wall
    obviously lots to consider such as ease of manufacture and cost
    Sep 2019
    197
    Okay, so i made a temporary gland plate from acrylic. Moved stuff around to be where they were supposed to be.
    Labeling of the plugs etc will be engraved into the gland plate
    My thinking was that if someone still had an old pc and used their pport then they would just plug into the 25p on the g540
    Obviously the ethernet port would not be used/blanked out, same for the 25p plug.
    Then if they choose the option of a motion controller then i already have provision for uccnc uc300 and smoothstepper
    Would be as simple as to use a short loop between the 25p on the g540 and the one just below it on the outside
    Reason for this is to reduce wiring inside the box
    What do you guys think????
    Many thanks
    Erick
    Sep 2019
    197
    Sep 2019
    197
    Anyone else with some advise???
    Please
    I need to finalize the design so i can start wiring and testing
    Sep 2019
    197
    Decided not to use the g540 and the vfd in this panel. Decided to keep things simple for a start. There will be four Leadshine drives 5.6A, with the option of a fifth drive in this panel. Motion controller either the ess or the uc300eth....good quality bob, power relay, power relays for external devices. Plugs for the spindle control start/speed. Also enough plugs for limits, e/stops etc. Automatic cooling control for the panel. Large capacity power supply for motors, 12V and 5V power supplies. Main switch, mains filter, mains fuse. Properly documented, diagram, all wire numbers added.
    Aug 2019
    339
    1. You need to think about the fact that we are entering 2020 soon. If you are serious about offering a turn key solution, and you want it to sell-out, you need to ditch that square shoe-box cabinet that everyone of us can build in a weekend with equivalent if not better components, and go completely crazy aesthetic-wise. Google image "DMG Mori controller" for inspiration (organic curves, led/el, honeycombs/meshed/brushed/anodized, etc).
    2. You need a powerful small board computer with built-in micro-controller + capacitive touch display on the control. For something capable of running both Linux & Windows, see LattePanda Co. (Alpha).
    3. So many other things, but I think you can clearly picture and understand where I'm going with this.
    Perhaps not the ideas you wanted to hear, and a bit harsh, but I'll say this again; "if you want to be able to market your product".
    Hope this helps none the less
    G'luck
    Sep 2019
    197
    Quote Originally Posted by Mecanix View Post
    G'luck
    Thanks for your input....i honestly do not know what the problem with the steel control box is. This only houses the equipment and can be tucked away from sight. The hmi side of things i do agree with you....however i see the computer and the motion control software as the "hmi". Installing a computer inside the cabinet is a good idea, i am just not sure people would like to pay for this....most guys i know are just using their laptops.
    I guess my idea is to supply a good quality control box for people who don't want to build one them self. Companies like cncrouterparts do something similar and they seem to be successful with it.
    From an Electrical safety point of view a steel approved enclosure is the standard. Once i have my website up and running i will see how the interest for this panel is, the idea will be to also supply cable and other stuff.
    Listening to what customers want/would like is obviously very important.
    As for people able to build the same panel or even something better is true....but also true for anything on the market.
    Sep 2019
    197
    The panel powered up and everything working great. Next will be to wire up the limits etc and test. I used single core cables to the spindle and cable tied the stepper cables to it on purpose to confirm resistance to electrical noise. All good, ran long programs to confirm that there are no lost steps. The final box for sale might look slightly different but i am happy with the results. Hopefully the cost will be on par with similar spec products.
    Sep 2019
    197
    Milled e few bits for the test rig, which will allow me to add bits to the stepper motors for testing positioning and torque.
    Aug 2019
    339
    Quote Originally Posted by ericks View Post
    I was more making reference to "innovative ideas" with cosmetic advancements (see DMG's screengrab) more than just copying what others have done already. In fact you are wrong about everyone using laptops; most if not all of the folks I know went with the latest touch-key control solutions now offered for ridiculous prices on several platforms (alibaba, taobao, banggood) (see other kits screengrab). Those works flawlessly well in most cases. Certainly far superior than parallel/usb based controls (Mach3 comes to mind).
    If you really want a piece of this market and have your efforts pay off, i.e. if this is really what you want to do/market, then I'd give it my best shot and aim in the middle (between the sexy DMG/Mori and near free control boxes). For one I'd l'd prefer buying a sexy unit over another metal box
    Sep 2019
    197
    Honestly i am not copying anyone's work, i am in the electrical industry and the way i am doing it is just standard practice. This is the way i have been building control boxes for a long time
    The fact that cncrouterparts use a similar box is just cause they doing it to the same standard.
    I am listening to what you are saying though.
    Mach3 is not something i would consider, been there done that, also no usb. My own machine runs perfect on Ethernet, that's why i am doing it the same. Regarding a touch screen, i will look into it in the future
    Again regarding the metal box, the box is what i have to use to house the mains equipment, re Electrical safety. It can be tucked away inside the machine stand. I guess cause i work in industrial field i make stuff with that in mind. I am aiming for people who want a good quality, practical and simple control box designed with safety in mind.
    ps....regarding the enclosure, i have designed my own aluminium box, nice looking compact unit. Will consider using it
    Thanks for your input, it's much appreciated!!
    Aug 2019
    339
    Let us know if you need any help for either organic curves modeling, up to the dedicated fpga's verilog logic blocks programming, or even vnck custom automation kits (like DMG's). Lots of amazing resources and talents on this forum. Happy to see you self-employ yourself, I may support by buying a kit from you when you are ready. Push it man, grab that market coz CNC 'anything' are soon to explode in everyone's garage & homes.
    G'luck
    Jun 2015
    943
    Mechanix, you comparing apples to oranges. He is building a control box with the motor drivers, breakout board, power supplies etc. And you comparing it to a CNC controller which is basically a signal generator with a human machine interface.
    Sep 2019
    197
    G'luck
    Thanks will do
    Sep 2019
    197
    This is what it looks like atm, there will be a few changes but regarding operation everything is working fine. Testing should be completed in a couple of weeks and the first boxes should be ready to go before the end of the year.
    Sep 2019
    197
    Update, basically done with the design, decided to use the AXBB-E motion controller and UCCNC license for the first box. Going to have a delay cause the steel enclosure supplier i use is out of stock for another five weeks. I ordered a couple from another supplier, received them today but sending them back cause i am not happy with the quality.
    I am very fortunate with my enclosure supplier, great quality box at a very reasonable price
    Sep 2019
    197
    Another update. After much research and consideration i decided to produce similar panels to the one on my own machine. So the panel will house everything including the VFD.
    My own setup works perfectly and there is "room" for upgrades. Obviously it will be for someone who wants something "Industrial".
Page 1 of 4 123
