585,959 active members*
4,309 visitors online*
Page 4 of 4 234
Results 61 to 78 of 78
  1. #61
    Jan 2007
    626
    Re: Need help please
    "If you build it...they will come....'
    lol
    You have a good strong product bro. You have rung its neck and it has come through easy.
    Keep going!
  2. #62
    Sep 2019
    197
    Quote Originally Posted by Sterob View Post
    lol
    Keep going!
    Thanks mate
  3. #63
    Sep 2019
    197
    So i decided to install the box on my own machine, that way i can prove that it works as required. Had to make a few mods on the stand to fit it...
  4. #64
    15362
    Quote Originally Posted by ericks View Post
    Nice Pro job time for some :cheers:
    Mactec54
  5. #65
    Sep 2019
    197
    Thanks mate
  6. #66
    Sep 2019
    197
    Set up uccnc for axbb-e. All working as expected, made a few bits. All that is left is to connect all I/O and external powered devices and do a thorough test
  7. #67
    Sep 2019
    197
    Update....all i/o connected and set up. Panel is working faultlessly. Time to make up a new unit for sale, a few little tweaks but essentially the same.
  8. #68
    Jan 2007
    626
    *Golf Clap*
    good stuff Erick.
  9. #69
    Sep 2019
    197
    *Golf Clap*
    good stuff Erick.
    Thanks Steve
  10. #70
    Sep 2019
    197
    A little update, all good with the control panel...0 issues. Just completed a pc board to make wiring between the motion controller and sensor/limit sockets easier and quicker. No more soldering of cables to sockets and adding heat shrink, and it should be a neat solution. Next board will be an expansion board to the AXBB-E to make it easier to connect/wire, open up more i/o and add some logic for external devices.
  11. #71
    Sep 2019
    197
    Yet another update....i managed to complete the first version of the pc board. With minor changes it will be good to use/sell. Will make wiring the i/o much quicker, easier and neater.
  12. #72
    Nov 2012
    1267
    I noticed that many DIYers wire their steppers using detachable connectors. Is there a good reason for that, or is it just a tradition? How often (and what for) do people disconnect/reconnect their motors? To me those chassis connectors just look like more wiring headaches and more potential points of failure.
  13. #73
    Sep 2019
    197
    Quote Originally Posted by CitizenOfDreams View Post
    These are not stepper connectors, they are just I/O connectors. Reason i do it is cause i want to sell plug n play boxes
    In the industry we gland our cables only...hardly ever use plugs, it's added cost and another spot where you can have issues.
  14. #74
    Nov 2012
    1267
    That makes sense. People without deep knowledge of electronics would probably feel much more comfortable plugging in clearly labeled connectors instead of attaching individual wires.
  15. #75
    Sep 2019
    197
    Yes
  16. #76
    Feb 2008
    10
    Are you ready to sell your i/o connector board yet? If so where can one order these?
    Ian
  17. #77
    Sep 2019
    197
    Quote Originally Posted by iforeman View Post
    Ian
    Hi Ian, this is only a prototype. I need to change a couple of things before i sell them. The idea is to make them very easy to install. These ones will be tricky to install, reason being the sockets need to be fitted to the box/gland plate first...then the pcb put in place and the pins soldered. I want to use different sockets that the user can solder first then push onto the box/gland plate and tighten from the outside. If you have a removable mounting plate and are able to machine the socket holes very accurately then i can send you one of these boards, no problem
  18. #78
    Sep 2019
    197
    This is how i did it initially, reason why i made this board is to make it neater and save time wiring...
Page 4 of 4 234
