585,712 active members*
4,068 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Retrofitting a spindle chiller onto a Fadal VMC15
    Feb 2007
    473
    Question Retrofitting a spindle chiller onto a Fadal VMC15
    Hey all!
    I'd like to retrofit a spindle chiller onto my VMC15, but I need to get clarification on which ports on the spindle are used for plumbing this in... Hopefully someone will be able to answer this! I've attached a couple of photos with my best guess for the coolant in port, I know the port on the spindle flange is for the air curtain because that's already connected and working fine!
    Also: does anyone know if all Fadal spindles were setup the same way internally in terms of plumbing? Given this machine did not come with a chiller will all the required seals and so on be present inside the spindle nose?
    Thanks for any and all help!
    -Aaron
    Gough Custom - http://goughcustom.com/
    Jan 2009
    52
    Re: Retrofitting a spindle chiller onto a Fadal VMC15
    Did you ever figure this out?
    Feb 2007
    473
    Quote Originally Posted by gwiz View Post
    I believe the drawing I posted above has the ports labelled correctly. I have not fully hooked it up yet but I did plumb it in while re-assembling the machine.
    Jan 2015
    417
    Your porting is correct. And i am 99% sure they would have the seals in there. You could put a little air to it and see if it holds. But during assembly they would just throw the o-rings in and be done with it.
    Rodney
    Feb 2007
    473
    Quote Originally Posted by rodney247 View Post
    Rodney
    Thanks Rodney! Good idea to check with air beforehand!
  1. Replies: 3
    Last Post: 01-01-2014, 04:15 AM
  2. Fadal VMC15 CNC88 spindle issues
    By DMCRacing in forum Fadal
    Last Post: 08-05-2013, 12:45 PM
  3. Chiller Pump for Fadal Spindle...
    By raps in forum Fadal
    Last Post: 02-25-2008, 03:31 PM
  4. Fadal 6030 spindle chiller
    By 5th-axis in forum Fadal
    Last Post: 10-24-2007, 12:55 PM
  5. Fadal VMC15 servo & spindle problems
    By FinnCNC in forum Fadal
    Last Post: 04-18-2007, 04:03 PM
