584,866 active members*
5,097 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Which pulley wheels and belt for Consew Motor to Taig?
Results 1 to 9 of 9
    May 2006
    309
    Can anybody here tell me the best option for pulley wheels and belt in order to mount a Consew CSM1000 Sewing Servo Motor to the original taig spindle block? Any links to an ebay seller or some other inexpensive dealers would have been fine.
    Nov 2009
    4415
    Re: Which pulley wheels and belt for Consew Motor to Taig?
    A lazy man does it twice.
    Apr 2005
    6
    Anyone have part numbers on the ones that fit?
    (closest fit)
    The link above is the index to the entire web-store.
    Jul 2008
    Quote Originally Posted by RedHouse View Post
    (closest fit)
    I have not completed boring out my pulley so I can't comment on efficacy, but I referenced this link: https://trains.socha.com/2018/11/tai...mach-mill.html
    20XL037-3FA7 Imperial Pitch Pulley -- 20 teeth, 5/8" bore
    40XL037-6A6 Imperial Pitch Pulley -- 40 teeth, 1/2" bore
    142XL037G Imperial Pitch Belt
    Apr 2005
    6
    :cheers:
    May 2006
    309
    One of the pulley is type 3F and the other type 6. What does that mean? Do you think they both will fit the same belt?
    And I see the 40xl pulley has a bore on 1/2 inch but the shaft on Consew is 15mm. Do you think this will be a better choice and fit to the belt?
    https://www.ebay.com/itm/40XL037-Alu...UAAOSwyO1asyIY
    Apr 2005
    6
    My Taig Mill's spindle measures 15.9mm, and a 16mm pulley fits ...but sloppy, so it wobbles when the set screws are tightened.
    (throws it off center just slightly)
    Same slop problem with the Consew, which (mine) has a shaft measuring 14.96mm and a stock 15mm pulley fits but sloppy.
    The pulleys seem to be bored slightly oversize.
    I guess I'll need to get some more pulleys, get undersize pulleys and see if I can find someone with a lathe that can/will bore them to proper fit.
    (sigh, ya, shoulda bought a lathe I guess)
    May 2006
    309
    Have you tried with a layer of scotch tape around the shaft or something similar? Maybe it will be possible to buy a thin sheet of 0.05 mm steel and use that between the shaft and the pulley.
    Apr 2005
    6
    Yeah that can be done and many do that,but I'd prefer to get a pulley (or modify a pulley) to fit properly without a work-around like shimming.
    I've ordered a couple more pulleys and that will take care of it.
  1. Motor to Ballscrew (1605) Belt & Pulley: Height Mismatch
    By Bravin Neff in forum Linear and Rotary Motion
    Last Post: 03-11-2019, 01:42 AM
  2. Which belt and pulley wheels for sewing machine motor?
    By jaru-eri in forum Taig Mills / Lathes
    Last Post: 09-09-2018, 07:32 AM
  3. Bridgeport CNC Quill Motor Pulley and X-axis Belt
    By glixons in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2013, 05:26 PM
  4. Toy Motor Brass Belt Pulley
    By rwburbage in forum Employment Opportunity
    Last Post: 11-15-2012, 02:45 AM
  5. X3 Motor Pulley / Belt Pitch?
    By ImagineRobots in forum X3/SX3/G0619/G0463
    Last Post: 01-18-2012, 03:43 AM
