586,009 active members*
4,900 visitors online*
Results 1 to 8 of 8
    Nov 2010
    11
    6040 Chinese cnc
    Hi all, if you can steer to the right direction I know the answer is probably in these forums, here goes I would like to use Mach 3 with this system.(6040) I have the USB CNC software with the parallel port to USB to the computer,can i use Mach3 with this set up???
    Pat
    Jan 2007
    626
    Re: 6040 Chinese cnc
    I guess we need more info....
    Do you have one of these?:
    https://planet-cnc.com/
    Are you using any particular software at the moment?
    If so, why do you want to use Mach 3?
    You could upload some pics that may clarify things for us.
    Apr 2005
    304
    Which interface do you have (USB -> Parallel)?
    You have to be aware that using Chinese USB controllers can be problematic with Mach3, which, BTW, ceased in development 6 years ago.
    I just obtained Russian external controller made by Purelogic R&D, PLCM-E3 accompanied with their software PUMOTIX. Works as advertised.
    Then there are more external controllers US/EU made like POKEYS, ESS, For these controllers there are plugins for Mach3 and Mach4. And you have UCCNC with their controllers and software.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Nov 2010
    11
    OK lets start with the controller box it has a parallel port and connects to the PC with the USB. The controller board is a JP-3163B. I am using the software that came with the machine (USB CNC). I have a question if I just use a computer with a parallel port can I use a printer cable connect it between the PC and Controller and just reconfigure the pin-outs with Mach 3?? I will take Pic's and post them later
    Pat
    Apr 2005
    304
    OK, your controller is NOT an USB controller. It is standard controller that accepts Step/Dir signals from PARALLEL port.
    You need some software that sends these signals over the printer port.
    Mach3 can do that, but you are limited with operating system that HAS to be 32-bit and not greater than Windows 7, or to use LinuxCNC.
    Nov 2010
    11
    Thanks ZASto, got mach 3 installed and got it running using the parallel ports, I have more work to do will take it one step at a time
    Thanks Pat
    Apr 2005
    304
    Nice to hear
    Dec 2018
    22
    Quote Originally Posted by pjf610 View Post
    Thanks Pat
    Great to hear. I have been using an old free computer with 1gb of ram for over a year now. And using a parallel port. No issues as all after set up.
    have fun
  1. Chinese 6040
    By FGS in forum Chinese Machines
    Last Post: 07-12-2019, 12:25 PM
  2. Please help with 6040 Chinese Laser
    By duoblade in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-09-2019, 01:13 AM
  3. My Chinese 6040 Experience So Far
    By kronick in forum Chinese Machines
    Last Post: 05-12-2018, 11:48 AM
  4. Chinese 6040 CNC Router
    By ecope in forum Chinese Machines
    Last Post: 11-02-2015, 10:07 PM
  5. 6040 CNC Router (Chinese)
    Last Post: 10-14-2014, 08:57 PM
