584,817 active members*
4,810 visitors online*
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Jun 2007
    37
    Re: problem motors not moving
    I did the jumper wire on the eStop. But still doesn't work
  2. #22
    Jun 2007
    37
    Here's my wiring
  3. #23
    15362
    Quote Originally Posted by rick027 View Post
    Did you reset the Ports and Pins for the E-Stop and look to see if it is working
    Mactec54
  4. #24
    Jan 2010
    77
    Look at the jumper. It's in a different location than the schematic diagram, but is shows you have your bottom pins set to input instead of output. It looks like if you move the jumper to pins one and two, it will change it to outputs for your motor drives.
  5. #25
    Jun 2007
    37
    Yes I did reset the eStop port and pin
  6. #26
    Jun 2007
    37
    I actually have moved that jumper to output...
  7. #27
    Jun 2007
    37
    Last night I took out the breakout board to inspect it, I flipped it over and it looks like one of the circuits is fried if you look at where it says AC7 ,looks like there's something missing
Page 2 of 2 12
  1. Help! Having trouble moving my motors
    By timbochung in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-25-2014, 08:34 PM
  2. Motors not moving (Geckos 202.)
    By stef_d in forum DIY CNC Router Table Machines
    Last Post: 08-23-2010, 07:07 AM
  3. Motors not moving
    By neric in forum DIY CNC Router Table Machines
    Last Post: 07-27-2010, 10:58 AM
  4. Mach3 not moving motors
    By jasper371 in forum Mach Mill
    Last Post: 06-15-2009, 10:32 PM
  5. Motors not moving
    By lamicron in forum Mach Mill
    Last Post: 05-20-2008, 01:54 AM
