585,754 active members*
3,717 visitors online*
    Nov 2017
    23
    4th axis #18 error
    Today I tryed to use 4th axis. But i can't use CS command because I recive #18 error for A axis. I wanna mention is a VM65 ... and when I can't turn the chuck by hand.
    Best regards,
    Nov 2017
    23
    Re: 4th axis #18 error
    Today I change the cards with X cards, error was the same ... axis A. Also today I disassembled the motor, I cleaned the old oil, check the backlash... everything is great there.
    Someone have other suggestion?
    Best regards,
    Aug 2009
    1570
    Its probably the AMP-0006 unit. There is a fuse on the board you can check.
    https://www.fadalcnc.com/index.php/amp-0006.html
    Nov 2017
    23
    Quote Originally Posted by machinehop5 View Post
    Can you tell me where is located, maybe a way to check it.. .machine works perfect without 4th axis.
    Today I checked just 1010-5 card.. i didn't know I have other unit responsable with my 4th axis.
    Aug 2009
    1570
    Not sure which Model Fadal you have....this is photo of a Model4020. The AMP-0006 is mounted on there
    Attachment 428422
  1. error 368 X AXIS : SERIAL DATA ERROR (INT)
    By mattpatt in forum Fadal
    Last Post: 02-24-2023, 02:01 PM
  2. Replies: 3
    Last Post: 02-19-2019, 04:37 PM
  3. Error 414 Z axis error detect- servo alarm
    By andywids in forum Fanuc
    Last Post: 07-09-2009, 04:33 PM
  4. Error 414 Z-axis error detect servo alarm
    By andywids in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2009, 03:56 PM
