585,568 active members*
3,566 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > cool way of doing small lathe ops on mill
Results 1 to 9 of 9
    Jul 2005
    969
    this is a neat little way of doing some small lathe operation on a mill
    http://www.youtube.com/watch?v=BOag3...elated&search=
    Mar 2007
    69
    This method has been around for a while. Particularly useful in large shops where you may need to do a simple lathe operation, but all the lathes are in use. Just put your stock in the spindle, a turning tool in the vice and have at it. Although this is the first time I've seen it done with a CNC mill. Pretty neat!
    (It was also described in Machine Shop Trade Secrets.)
    Apr 2005
    403
    That is slick!!, Gives me a couple of ideas.
    Ron
    Nov 2006
    154
    Perhaps this is known as creative machining, doing something on one machine that was designed to be done on another.
    A CNC lathe basically has two axis where a CNC mill has three..can you imagine the mill also acting as a pick, machine, place, and start over again? One can only imagine the possibilities with a little creative programming and a wide open mind!
    Steve
    Feb 2007
    632
    That has got to be the neatest way to do milling. Definitely gave me some ideas.
    I wonder how the G Code would look like.
    Jan 2007
    62
    Thread in reverse...
    Has anyone ever used a lathe for drilling/milling square stock?
    I don't have a vertical mill, and I would like to drill larger (7/8") holes for my linear bearings in aluminum with greater accuracy than can be achieved with my drill press. I have a metal lathe of substantial capacity. I'm thinking about chucking my bit into the headstock and shimming the workpiece to the right height on the sled, clamping, and then choosing a slow feed to drill the hole.
    Just wondering if this is something anyone has done!
    Brian
    15362
    Hi ataxy
    We have been doing Turning in our Mills for more than 20years we have 2 mill set up all the time we also use expanding mandrels which are controlled buy the spindle draw bar if you want to turn large diameter parts you need a good
    spindle and at least 7HP to get the job done the tool changer can also be loaded with blanks mounted on tool holders, and if parting parts off in the spindle ( Like in the movie ) you need to have a part catcher or the parts
    can get dinged up
    Mactec54
    Quote Originally Posted by boguski.1 View Post
    Brian
    I actually used a lathe to "mill" a 4x3x5 block of aluminum when the bridgeport was tied up.
    used a 4 jaw chuck and indicated the part parallel with the x axis for each side before facing it off.
    It came out perfectly square.
    then bored it out for the spindle and bearings.
    it's the first pic on this page.
    http://www.hossmachine.com/projects_5.html
    Mar 2007
    69
    Quote Originally Posted by hoss2006 View Post
    This is way people used to make "Turner's Cubes" (the little cube within a cube within a cube toys that can be found in many machine shops.) There is little article about it in The Machinist Bedside Reader #3 on page 219. (They also used foot powered lathes!)
    -Bob
  1. Replies: 15
    Last Post: 05-05-2011, 11:59 PM
  2. How cool is this CNC lathe!
    By chola in forum Mini Lathe
    Last Post: 12-06-2006, 02:48 PM
  3. Lathe Comparison - Best small lathe for CNC
    By acondit in forum Mini Lathe
    Last Post: 03-24-2006, 02:10 AM
  4. RFQ: Small mill/lathe job
    By vadimvc in forum Employment Opportunity
    Last Post: 03-14-2006, 05:10 AM
  5. small production run - live tooled lathe and mill prolly required
    By Vitamin-E in forum Employment Opportunity
    Last Post: 02-22-2006, 03:12 AM
