585,722 active members*
4,482 visitors online*
    Nov 2003
    108
    finding center of a hole
    I have an edge finder with a conical end, which I guess may be used for finding the center of a hole.
    In the Mach 3 offsets window, there is an area for using an edge finder to set the offsets.
    I have played around with this and haven't got it to work just right.
    I would like to be able to use this to find the exact center of a hole and then set this as X0, Y0.
    Could someone please give me a step by step on how to do this.
    Thanks.
    Jan 2007
    355
    It's much easier to find the center of a hole using a dial test indicator.
    A spring action contact point easily adjusts to any angle. A needle on the graduated dial indicates how far the contact point moves.
    Mount the indicator in the spindle, locate the contact point against the hole wall, and position the X&Y axes until the needle shows no movement (while rotating the spindle by hand).
    You are now perfectly centered in the bore.
  1. need help finding a cnc lathe
    By joey1117 in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2007, 11:02 PM
  2. Finding the center
    By Tazzer in forum MetalWork Discussion
    Last Post: 08-05-2006, 06:18 PM
  3. Drilling a hole in the center of a bolt / newby question
    By stickben in forum Mechanical Calculations/Engineering Design
    Last Post: 04-30-2006, 05:07 PM
  4. Help with finding DWG converter
    By Enos Shenk in forum G-Code Programing
    Last Post: 12-20-2005, 01:56 AM
  5. Need help in finding
    By brtlatjgt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-03-2005, 05:31 PM
