585,752 active members*
4,091 visitors online*
    Jul 2010
    7
    Mori Seiki Tool Life Alarm
    We have 2 Mori Seiki ZL-25s with the MSC-516 control. We are using the tool life management on these machines. The problem is that one of the machines does not stop the machine from running once the tool life is used up. On the machine that works the way we want it to, the machine will not cycle again until the tool life is reset on the offending tool. On the machine that does not work the way we want it to, we get a message on the display that says the tool is used up, but if the operator doesn't pay attention, they can hit cycle start and the message goes away and the machine will keep running. Is there a setting somewhere that I am missing to prohibit the next cycle?
    Mark
    Sep 2019
    14
    There may be a parameter setting for tool life management. You can check the 2 ND machine and verify the parameters are set the same in both.
  1. Mori Seiki SH50 alarm 414 Servo Alarm
    By Ososa in forum Mori Seiki Mills
    Last Post: 05-24-2017, 08:23 PM
  2. MORI SEIKI SL-25 LUBE ALARM
    By barnhill1 in forum Maintenance DIY Discussion
    Last Post: 02-19-2014, 05:32 PM
  3. Mori Seiki SL3 spindle alarm
    By woofa in forum Fanuc
    Last Post: 09-07-2013, 08:36 AM
  4. MORI SEIKI CL-20 ALARM!!!
    By GMI in forum Mori Seiki lathes
    Last Post: 07-26-2011, 04:46 AM
