585,712 active members*
4,218 visitors online*
    Sep 2017
    6
    Question Sinumerick 802c full memory i can't delete files
    Hello I have a sinumerik 802 S that when loading an extensive CAD file exceeds the file memory, and I cannot delete it. Is there any way to erase everything?
    Aug 2019
    339
    Re: Sinumerick 802c full memory i can't delete files
    Not entirely sure what you mean by loading CAD data (?) into a 802 controller, although I know what erase everything means, not sure this is what you should do though :/
    I'll assume you loaded any file and the file system locked it (corrupted). Few things you could try first; one being to ensure you are logged in/key'ed in the manufacturer access level, second would be a sys shutdown/reboot, third would be to using the Siemens' Access MyMachine P2P software for file system access when the ctrl in on reset (if you have IP networking interface).
    Where are you in the debug? What steps have you already taken to try to get this sorted?
    Sep 2017
    6
    Quote Originally Posted by Mecanix View Post
    Hello sorry but it is not a CAD file but a CAM / CAD file made with a PC.
    And on the other hand, I can't access the reading of any file created in memory, so I need to delete everything.
  1. Mentor needed for Sinumerick 802C questions -
    By GUIDOSAN in forum Mentors & Apprentice Locator
    Last Post: 04-23-2013, 12:56 AM
  2. Full capacity Memory but no files showing
    By WINGNUT66 in forum Fanuc
    Last Post: 04-19-2012, 12:42 AM
  3. how the f*** do I delete files on a Centurion7?
    By glenthemann in forum Milltronics
    Last Post: 03-18-2011, 02:24 AM
  4. WKlaser usb stick files to delete?
    By Micheal Donnellan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-30-2008, 08:58 PM
