585,926 active members*
3,999 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > Need a littel help with Okuma Threading
    Nov 2016
    Im trying to make a 5/8 18 2A Thread. Ive been programing and running haas Lathes and mills the last 8 years and recently switched to a new employer. they have haas mills but only one lathe - Okuma Crown OSP700L.
    Im unfamiliar with all of the okuma codes and how they should look. They do not have a manual and i cant find one online. hoping you guys can help me.
    This is the Code my software puts out
    G71 X0.545 Z-0.43 B60 D0.01 U0 H0.08 L0 F25.4 J18 A360
    Feb 2011
    353
    Re: Need a littel help with Okuma Threading
    THIS IS FROM AN OSP500L THIS SHOULD BE CLOSE TO WHAT YOU HAVE
    G71X.354Z-2.100B60D.007U.002H.04J30F1
    X= X FINAL DIA.
    Z=Z FINAL Z LENGTH
    B=CUTTER TIP ANGLE
    D= DEPTH OF CUT FIRST PASS IN DIA.
    U=FINISH PASS IN DIA.
    H=THREAD HEIGHT IN DIA.
    IN THIS EXAMPLE
    J=THREADS PER INCH
    F=1
    SO THAT ITS READ AS " F/J" =PITCH OF THREAD
    IF NO J WORD IS PROVIDED F WOULD BE THE PITCH OF THE THREAD AS THE CONTROL ASSUMES J=1
    L=CHAMFERING DISTANCE
    A=TAPPER ANGLE
    Nov 2016
    thank you for your help. this cleared up alot of my questions and i was able to make parts
    Feb 2011
    353
    your welcome
  1. G71 Threading for Okuma Lathe
    By pedgette in forum G-Code Programing
    Last Post: 04-12-2020, 08:00 PM
  2. Okuma OSP Lathe Threading G32 Alarm
    By dustpan3 in forum G-Code Programing
    Last Post: 10-31-2016, 10:47 AM
  3. Need littel help.
    By wickedone in forum Mastercam
    Last Post: 04-16-2016, 01:28 PM
  4. Okuma LC-20 Threading problem
    By Gunner in forum DNC Problems and Solutions
    Last Post: 12-14-2011, 05:11 AM
  5. NEED LITTEL HELP
    By dareformore in forum ArtCam Pro
    Last Post: 03-16-2011, 03:41 PM
