585,719 active members*
4,054 visitors online*
Results 1 to 15 of 15
    Jul 2019
    11
    Mazak Integrex 70
    Hello everyone, please help, machine mazak integrex 70.Control system Mazatrol T plus. Cannot perform tool change. Who knows how to write a tool change command correctly? In MDI mode, enter T0101, there is no reaction. Help me please
    Oct 2016
    106
    Re: Mazak Integrex 70
    Add M6
    Sent from my D5803 using Tapatalk
    Jul 2019
    11
    Quote Originally Posted by tspiszak View Post
    Add M6
    Does not react at all, the very fact that he read the command, and did not work. And you do not know, do you have to drive yourself to the tool change point? or is he himself? The machine does not even move, only the coordinates blinked on the counter, as if it had worked for something, but in fact, nothing happened.
    Oct 2016
    106
    Try T000t0m6, second t is to preload next tool.
    Jul 2019
    11
    I tried T001T002M6, nothing happened
    Oct 2016
    106
    Does it work in auto mode?
    Jul 2019
    11
    No theey does'not .
    Oct 2016
    106
    Call mazak
    Jul 2018
    31
    Hello,
    Is there a tool inside the electrospindle ? if yes then,
    T1xx is the command for unloading the tool, where T1 is electrospindle number and xx is the tool number.
    Example:
    ISO = T101M6 tool 1 loading demand from the spindle1.
    ISO = T116M6 tool 16 loading demand from the spindle1.
    Also you need to check the inputs from the spindle like, tool lock/unlock, tool present/abscent, tool sensor on magazine. Does it shows any error on screen ?
    regards.
    Jul 2019
    11
    Quote Originally Posted by coc9 View Post
    Hello,
    Example:
    regards.
    The M6 command unclenches the cams, so this command cannot be used to change the tool.
    Jul 2018
    31
    Did you check for sensor inputs ? And any errors on screen ?
    Jul 2019
    11
    what sensor check for inputs ?
    No errors . Maybe the error is that the command to change the tool is not correctly entered? There are 2 tool stores
    Jul 2018
    31
    I havent worked on this machine but in order for machine to know which tool is where, or if the tool is present on the holder/tool carriage/spindle there are sensors which send signals to the PLC (Programmable Logic Controller) so that when present/or absent (which ever is required) the machine does the further work. But when the required signal is absent the machine stops and (if programmed) give certain errors.
    Jul 2019
    11
    Thank you all, the problem has gone away to the decisions of the correct syntax for programming a tool call, namely T9000.8, which corresponds to tool number 9 in horizontal mode.
    Quote Originally Posted by endaeron View Post
    what year is your integrex? mid 90s?
  1. Mazak Integrex 70
    By endaeron in forum Turning Machines
    Last Post: 10-02-2019, 10:38 AM
  2. mazak integrex 200-ii sy
    By bmatty2001 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-29-2013, 11:07 PM
  3. Mazak Integrex 35
    By GCODE_FAN in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-17-2013, 11:39 AM
  4. Mazak Integrex 200 IV
    By Techman2 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-20-2012, 05:11 PM
