585,942 active members*
3,400 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Home CNC Router Questions
    Cool Home CNC Router Questions
    Hello from Newbie!
    I am looking to purchase a CNC router for home hobby projects but want to get some feedback from people who have purchased one already. Here are some questions I have:
    What kind of CNC router do you have? Where did you purchase it? How much did it cost?
    How often do you use your router?
    What materials do you like to cut?
    What size endmill bits do you use?
    What is the longest length endmill you use, when measured by protruding from the bottom of the collet?
    What is the shortest length endmill you use?
    What is the typical thickness of stock you use for routing?
    Do you use any method of dust collection now? If so, please describe your setup?
    Did you purchase any additional CNC router accessories such as hold down clamps, table, enclosure, tool height measurements, etc..
    Thanks in advance! I am one who really does my homework before making big investments.
    Jul 2018
    6334
    Re: Home CNC Router Questions
    Hi Strigg - What we use our machines for is not much relevance. What do you want to do with a machine? Peter
    Feb 2020
    I purchased a 3018 Vevor through Amazon. It works well but did take some time to get my computer to work with it. I use it daily mainly for engraving. I am now working on engraving the back side of glass. I use the standard engraving bits for plastic/wood/etc. 1/4"/-1/8" stock. I have a vacuum but it is so noisy I only use it after milling. As far as accessories I use clamps or just bolt to the t-slots
    May 2005
    1662
    Dust shoe + dust collector + 4" hose.
    The first time I used a cnc router was some pretty aggressive cuts in 3/4" plywood with a 1/2" cutter. Dust was expected but ...wow.
    Controlling the dust became a necessity, not an accessory. If doing lighter work it's possible to Shopvac the mess but I don't recommend it.
    sums it up
    Anyone who says "It only goes together one way" has no imagination.
    Nov 2013
    4371
    Hi strigg,
    I think the real decision point for you is 'do I want to cut metals?'.
    Cheaper Chinese made CNC machines will lightly engrave and even cut, albeit slowly, metals like aluminum and brass but you can forget steel.
    The machines are just not rigid enough. Machine rigidity really determines the cost of the machine....there is just no way around that.
    If you want to cut wood and/or signwriting materials many of the Chinese machines work pretty well. The weakest point of he cheap machines is the
    electronics, they are unreliable and sometimes near impossible to get to work properly. You would be wise to allow several hundred, maybe as much as $500,
    in the budget for upgrading the electronics.
    Craig
  1. Home questions
    By twin2turbo87 in forum Benchtop Machines
    Last Post: 05-08-2014, 03:47 AM
  2. Home Switch Questions?
    By DistortedDesign in forum CNC Machine Related Electronics
    Last Post: 06-19-2013, 12:10 AM
  3. 4x4 home built with pics and some questions
    By greenjeens in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-06-2012, 07:41 AM
  4. new to building a cnc setup for home use, many many many questions
    By sdwolff98 in forum T-Slot CNC building
    Last Post: 01-01-2012, 05:15 AM
  5. New guy questions home position
    By washingtondude in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-19-2006, 03:46 AM
