585,568 active members*
3,752 visitors online*
    Jun 2014
    4
    Question G71 G-Code Issue
    Hi Everyone,
    I have been placed in charge of a very old(not old as me btw!) CNC Ann Yang Lathe.
    the issue I'm having is to understand the G71 cycle it uses.
    The following are an inside an outside sample i have got to work.
    It uses Type A G Code according to the documentation.
    Now Questions,
    1. What brand of G Code is it?
    2. Why does a simple two line G71 code not work?(not the Single line type 2 BTW)
    3.Can some one explain how to combine multiple steps in this style of G Code?
    HAAS and Fanuc don't seem to fit this model in various ways.
    First two lines are fine, its just the P to Q lines that are throwing me ATM
    And finally does anyone know of an offline G Code generation program that utilizes the bulk of the Canned Lathe Cycles?(Free or at a reasonable price)
    Internal(Works Fine)
    G71 U0.200 R0.5;
    G71 P14 Q15 U-0.200 W0.125;
    N14 G00 X89.500 Z0.500;
    G01 X89.500 Z0.000;
    G01 Z-25.000;
    G01 X84.000 Z-25.000;
    N15 G01 U-2.000;
    External(works Fine)
    /* Turn Diamater */
    G00 X121.000 Z1.000;
    G40;
    G71 U0.500 R0.5;
    G71 P110 Q150 U0.125 W0.125;
    N110 G00 X110.000 Z1.000;
    G01 X110.000 Z0.000;
    G01 Z-110.000;
    G01 X120.000 Z-110.000;
    N150 G01 U2.000;
    G00 X120.000 Z1.000;
    G70 P110 Q150;
    G00 Z5.000;
    G40;
    (Doesn't Work)
    G71 U0.125 R0.5
    G71 P80 Q90 U0 W0;
    N80 X60;
    N90 Z-75;
    Regards
    Wes
    Dec 2012
    395
    Re: G71 G-Code Issue
    Hey Wes,
    /* Turn Diamater */
    G40;
    G71 U0.500 R0.5;
    G71 P110 Q150 U0.125 W0.125; ( -- add a F... for roughing )
    G01 X110.000 Z0.000; ( -- add a F... for G70 finishing )
    G01 Z-110.000;
    N150 G01 U2.000;
    G70 P110 Q150;
    G00 Z5.000;
    G40;
    (Doesn't Work)
    X40. ( add a start diameter )
    G71 U0.125 R0.5
    G71 P80 Q90 U0 W0; ( -- add a F... for roughing )
    N80 X60; ( add a G01 )
    N90 Z-75;
    Regards.
    Heavy_Metal.
    Jun 2014
    4
    Thanks Heavy_Metal, however the one that doesn’t work has a prep move the same as the others, I just didn’t put it in. The roughing feed is a standard rate placed at the start of the program. If you need a fine feed it iis placed within the P and Q blocks in this one.
    i have found that a G00 move has to be the first move to the first diameter and I think that’s the reason the last example doesn’t work.
    its looking like a Haas style code I think.
    regards
    Wes
    Dec 2012
    395
    Quote Originally Posted by ozwes007 View Post
    regards
    Wes
    We have a Haas NextGen controlled lathe and it has the G71 with one line code, so not like our Fanuc lathes.
    Feb 2006
    1792
    May like to read this for detailed information on Fanuc 2-line G71/G72.
  1. G code issue with arc ijk
    By gr3g0rs in forum Autodesk CAM
    Last Post: 06-28-2017, 10:19 PM
  2. Issue with G Code
    By nova24 in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-14-2012, 11:19 AM
  3. G code issue
    By bipe in forum Mastercam
    Last Post: 12-14-2010, 01:01 AM
  4. G-code issue on G81 / G99
    By tikka308 in forum BobCad-Cam
    Last Post: 03-30-2008, 09:01 PM
