585,926 active members*
3,868 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > STL files are not visible
    Feb 2017
    12
    I'm using ver27. I have a 3d drawing I have saved as a dfx file. I also saved the same 3d drawing as a stl file
    When I load bobcad and open the dfx version of the 3d file it opens as it should.
    When I open the stl version of the 3d drawing in bobcad its invisible,can't see it. I think its there because its blocking a portion of the x and y mm hash marks where the drawing should be located. Any one know why this is? Top
    Jun 2008
    1838
    Re: STL files are not visible
    It is possibly there but it may be the same colour as the background and will be in Top view, try selecting an ISO view and also try using the "Select All" facility, if nothing shows then there is no file present.
    If it is there it should show up, have a look at the bottom left of your screen and if the file is there then you should see a Tab named BobCAD1 and also a Tab with the name of your STL file. Not sure why you would want a .STL file as you are not able to work on such files in BobCAD.
    Feb 2017
    12
    Quote Originally Posted by The Engine Guy View Post
    Engine Guy
    I selected ALL as you suggested and the drawing showed up. The reazon for wanting the stl file to show up was curiosity as why I could see it. I use the stl file for a 3dprinter.
    Thank you very much for helping me out on this
    Gary
  1. Visible CO2 Laser
    By SPT-Laser in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 05-26-2017, 08:25 AM
  2. Visible CO2 Laser
    By SPT-Laser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-20-2017, 06:27 AM
  3. GCODE not visible
    By whagkangmakulet in forum Tormach PathPilot™
    Last Post: 04-30-2015, 06:22 PM
  4. Exporting DXF Files - Dimensions not visible
    By jwreeddesign in forum Solidworks
    Last Post: 02-20-2013, 07:49 PM
  5. CO2 laser visible?
    By nicklv in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-28-2007, 05:35 PM
