584,830 active members*
5,681 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > How to show Rpm instead of frequency? FVD yl620-a
Page 1 of 2 12
Results 1 to 20 of 26
    Oct 2019
    Hello, sorry my english (google translator).
    I really need your help.
    I bought a Fvd and I can't show the Rpm on the display, just shows the frequency. In the manual does not say where to change this option, and already read in several places to change the parameter p144, but in my model this parameter does not have.
    https://pt.aliexpress.com/item/32807...2742b90atvjpGQ
    110v 2.2kw
    Thanks a lot if anyone can help me
    Oct 2019
    Hello. I am sending 2 pdf manuals to see if anyone can help me adjust what I need.
    Dec 2013
    5717
    Re: How to show Rpm instead of frequency? FVD yl620-a
    Looks like set P00.24 = 6
    Maybe also need to adjust P00.23, but I think not.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2019
    Thanks, I did that what you said, I had tried that too.
    But it still didn't work.
    In P00.23 it only adjusts from 0 to 100.
    in P00.24 I put in 6. Now shows on the display SP 1.
    There must be somewhere else to change, but I don't know where, this is hard.
    May 2016
    5
    Hello, I have the same vfd did some one find out how to display rpm instead frequency on yl620-a?
    15362
    Quote Originally Posted by agflex View Post
    110v 2.2kw
    The DISP should select the RPM, just Press it until the RPM led is on then it will show the RPM
    You could try P00.24=9 this will give you all the options
    Mactec54
    May 2016
    5
    Hi mactec54, Really appreciate for the reply,
    I press DISP button 50 or more times no response, and I tried P00.24=9 displays u 9, and P00.24=6 displays SP 1, and there is no RPM display
    15362
    Quote Originally Posted by shakil1740 View Post
    Set it back to the default=0 and try the DISP again I'm not a fan of this VFD Drive as many users have had problems with them
    Mactec54
    Sep 2020
    11
    Foto giri del motore
    Enter on 00.23 = 50/60HZ it depends on where you are in Italy and 60hz
    Enter on 00.24=0
    Press the program button to return to the frequency, then press nine times on set until you reach RPM spindle on the display there is a lowercase u on the bottom left with the engine running you will see the engine rpm
    15362
    Re: Foto giri del motore
    Quote Originally Posted by Cosimino71 View Post
    Enter on 00.24=0
    This is an old thread
    He can not use 50Hz or 60Hz Parameter settings with his motor they must be set to 400Hz or he will damage his spindle motor
    Mactec54
    Sep 2020
    11
    If on 00.23 you put 400hz the spindle marks 6000 rpm as the maximum speed, if you put 60hz the spindle reaches 24000 rpm
    15362
    The P0023 you have a choice as to what you want and how to use it ( it is a % setting ) it has nothing to do with the main frequency
    Mactec54
    Sep 2020
    11
    Hello as I am new in this forum and I would like to understand my cnc machine well I followed the discussion regarding the vision of the spindle speed and I set those parameters to be able to see it the main parameters are on 400hz but I notice that the spindle heats up after 15 minutes even if I take it over six thousand turns my spindle and the one in the attached photo and I have a YL620-A vfd
    15362
    Air cooled spindles most can not run at 6000 RPM the minimum speed is normally in the 12,000 RPM to 18,000 RPM or they will over heat from low air flow
    Some Parameters may help, what Parameters have you set
    Mactec54
    Sep 2020
    11
    Which parameters determine the heating of the spindle and its good functioning so I check and let you know the ones that I have set
    Sep 2020
    11
    These are the parameters stored on my Vfd
    P00.00=400
    P00.01 = 0
    P00.02=0
    P00.03=0
    P00.04 = 400
    P00.05 = 400
    P00.06 = 100.0
    P00.07 = 400
    P00.08 = 146
    P00.09 = 0.2
    P00.10 = 2.0
    P01.00 = 0
    P01.01=0.0
    P01.02=140
    P01.03 = 140
    P01.04 = 200
    P01.05=130
    P01.06=120
    P01.07=80
    P01.08 = 150
    P03.08 = 40.0
    P03.09 = 400
    P06.01 = 10
    P06.02 = 10
    P0700 = 0.1
    P07.08 = 0
    P11.01 = 220
    P11.02 = 7.0
    P11.03 = 400
    P12.00 = 5.0
    P12.01 = 220
    P12.02 = 2
    P12.03 = 30
    P12.04=5
    P12.05=6,5
    P12.06=220
    P12.07=140
    Sep 2020
    11
    P00.00=400
    P00.01 = 0
    P00.02=0
    P00.03=0
    P00.04 = 400
    P00.05 = 400
    P00.06 = 100.0
    P00.07 = 400
    P00.08 = 146
    P00.09 = 0.2
    P00.10 = 2.0
    P01.00 = 0
    P01.01=0.0
    P01.02=140
    P01.03 = 140
    P01.04 = 200
    P01.05=130
    P01.06=120
    P01.07=80
    P01.08 = 150
    P03.08 = 40.0
    P03.09 = 400
    P06.01 = 10
    P06.02 = 10
    P0700 = 0.1
    P07.08 = 0
    P11.01 = 220
    P11.02 = 7.0
    P11.03 = 400
    P12.00 = 5.0
    P12.01 = 220
    P12.02 = 2
    P12.03 = 30
    P12.04=5
    P12.05=6,5
    P12.06=220
    P12.07=140
    15362
    By your list you have all the important Parameters set correct, some of these air cooled spindles do get hot, that is why the water cooled spindles are better have you been able to check what the temperature gets too
    Mactec54
    Sep 2020
    11
    So my parameters are fine my spindle motor and 0,8KW 220v 6,5A 400HZ is my VFD 1,5kw 220v 7,0A 2,8KVA
    Sep 2020
    11
    Since you are very kind and prepared I would like to ask you how to install a diode laser that I had on my cnc 3018, I would like to put it on my new cnc with mach3 system the spindle I command it with the Vfd panel but I would like to control the laser from the system but I don't know what I need.The 15w laser has three wires and is equipped with ttl that you can control with pwm I am sending you the photo of the controller attached
Page 1 of 2 12
  1. YL620-A VFD setting question.
    By regpye in forum Spindles / VFD
    Last Post: 03-25-2021, 12:44 PM
  2. Vfd YL620-a initial setup
    By Terryble24 in forum Spindles / VFD
    Last Post: 12-20-2020, 05:04 PM
  3. Seeking info on proper settings for a YL620-A VFD
    By SpyderHelix in forum Phase Converters
    Last Post: 06-02-2019, 09:22 PM
  4. YL620-A
    By slasher102 in forum Spindles / VFD
    Last Post: 11-06-2018, 07:00 PM
