585,967 active members*
4,365 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > Weird moves on the lathe ( please help solve this) (see pictures)
    May 2008
    667
    I will try to explain the best I can but this is really weird.
    I can only move 1 axis at a time no matter how I connect both stepper drivers.
    See pictures
    Normal connection
    Z+ and Z minus are working as they should
    No move on the X axis
    If I switch signal cable ( X signal on Z stepper driver and Z signal on X stepper driver)
    No move on the Z axis
    X axis become Z axis
    If I switch power cable going to stepper motor (signal cable in normal position x signal to X stepper driver --Z signal to Z axis driver)
    Z axis become X axis
    If I switch both, signal cable and power cable (from X to Z and Z to X)
    X axis move
    Re: Weird moves on the lathe ( please help solve this) (see pictures)
    Seems X axis stepper driver has problem.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    May 2008
    667
    Thanks for the reply.
    But if you look at pic #3, X axis move
  1. CNC lathe C axis resonates (moves back and forth)
    By semenov419 in forum Uncategorised MetalWorking Machines
    Last Post: 12-21-2017, 07:17 AM
  2. How to generate -X moves in CB Lathe ???
    By twocik in forum CamBam
    Last Post: 04-06-2013, 02:32 AM
  3. Replies: 4
    Last Post: 12-17-2010, 11:09 PM
  4. Pictures of my lathe Blueprinting
    By digitalmdj in forum Shopmaster/Shoptask
    Last Post: 01-19-2010, 01:45 AM
  5. Pictures of My Lathe & CNC MILL
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2005, 11:07 PM
