585,888 active members*
3,988 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Edgecam generating new post help
    Mar 2007
    21
    Hi
    I’m trying to make a post using the code wizard edgecam 2020. I’ve went through all that’s required but I can’t load it into the available posts I once in the edgecam program. I think I may have to generate a couple of other files as the posts that can be loaded have 3 files the same and I don’t know how to do this! Any words of wisdom appreciated. Thanks
    Oct 2003
    127
    Re: Edgecam generating new post help
    you have to press the "compile" button for wizard to put the generator in the list, have you done that?
    it looks like a sheet of paper with a gear in front of it.
    i think "ctrl+I" shortcut will also activate compiling
    Mar 2007
    21
    Quote Originally Posted by timf View Post
    Hi Tim
    Thanks a lot that’s worked, something so simple!! Feel kinda stupid.
    I did the hardest bit then went looking to generate the code without full filling the code generator process, think I was just a bit too keen!
    Thanks again now I’ll have ago at making up a post for conversational Heidenhain. Hopefully it’s as straight forward as the Fanuc.
  1. Generating .gpx post-processor
    By MilanTristan in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-15-2022, 11:39 PM
  2. POST ISSUE EDGECAM 2011 fanuc milling post
    By MACHINE GOAT in forum EdgeCam
    Last Post: 01-30-2019, 11:22 PM
  3. Replies: 8
    Last Post: 11-28-2016, 01:54 AM
  4. Post generating really small erroneous radii circles?
    By Brian Corwin in forum BobCad-Cam
    Last Post: 05-05-2014, 09:03 PM
  5. Post generating, non-executable gcodes
    By cansucuoglu in forum Post Processors for MC
    Last Post: 03-17-2008, 05:25 PM
