585,982 active members*
4,722 visitors online*
Results 1 to 3 of 3
    Jul 2019
    6
    Laser arcing on annode connection
    Hello,
    I am fairly new to this and have been trying to setup a 40w laser on a greenbull cnc. I'm extremely new to this and was unable to find a lot of good documentation so have been struggling to get this to work for weeks. I have it setup correctly and can get it to test fire with no issue when I press the test button on the power supply and am now working to get it to fire using the cnc usb software. I could not get it to work so I used the test fire button to make sure the laser was still active and accidentally shocked myself.
    When this happened I pulled the high tension line loose without realizing it and did a few more test fires over the next 30 minutes with no issue. Then I started seeing the arcing on the video and smelling smoke. I realized the line was not attached to the power supply so I reconnected it and now I can't get the laser to fire at all. Have I ruined the tube or is this something that can be fixed?
    As far as I can tell the line is still connected securely to the terminal and I removed the old tape and added some more.
    The control board is a mk1 board from buildyourcnc.com
    arcing: https://youtu.be/Oz-KLH1-WZU
    laser tube: https://buildyourcnc.com/item/Laser-...ube-CO2-40Watt
    power supply: https://buildyourcnc.com/item/Laser-...Supply-CO2-40W
    I am really struggling with this and would appreciate any help.
    Oct 2019
    37
    Quote Originally Posted by pacguy View Post
    Hello,
    Hello,It seems your CO2 laser source was burned.I will also check this with our engineers,and update to you asap.
    James
    whatsapp:18600395818
    Email:[email protected]
    Oct 2019
    37
    On the other hand,it seems 40W is too lower power for your working request.
  1. Ten-High Laser Engraver - Laser not firing, now arcing
    By clydehestur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-13-2019, 04:29 PM
  2. Laser arcing!
    By sambyerley in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-23-2018, 03:03 PM
  3. Laser tube arcing
    By Dtcrafts in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-24-2017, 06:21 AM
  4. Arcing connection on Laser CO2 tube connection
    By pcaulfie in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 11-06-2015, 07:00 PM
  5. 50watt laser cnc arcing
    By stiyke in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-13-2014, 06:24 PM
