585,974 active members*
4,219 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP-300M M560V Best practice for Manual Tool Change Mid-program
    Oct 2019
    ETA: I found the solution right under my nose, with Mid-Auto/Manual. Hadn't beed using this feature previously due to various reasons, but my issue is solved.
    Hello all.
    I am having some difficulty working through the issue of completing a manual tool change (to remove an oversize tool ffrom spindle) in the middle of a program and resuming the program from that point.
    The machine is a Genos M560-V vertical mill with an OSP-300m controller. When I toggle into manual mode to remove the tool from the spindle, and back into auto mode, the program resets to the beginning.
    Am I missing something simple here?
    crays
    Jun 2015
    4154
    Re: OSP-300M M560V Best practice for Manual Tool Change Mid-program
    hy crays so, there is :
    ... like you said, mid-auto + manual
    ... step-by-step, manual intervention
    an alternative would be to split your program in 2 parts, so to change the tool between programs : like this, you may avoid the "intervention" thus, is good to know how to do this sequence, but try to avoid it whenever possible, especially because the machine may restart without restoring the previous rpm ( it's just another thing between the "mil team" and "lathe team" )
    also, if you wish, please check the dimensions and weigth of your tool, with those from the machine catalogue, so maybe you can avoid the manual intervention, by using a "heavy-tool" setting inside the atc
    i do not recommend changing heavy tools by hand, if at least you can hold that tool long enough, without arms fatigue, and without aligning the tool in such a way, that it is clamped from the 1st time : if you can endure and keep the tool in your hand all-day-looooooong, but the machine spindle won't clamp it right from the 1st time, because of alingment issues, then you have a big chance to damage the pullstud, and also that damage will be reflected inside the pulling mechanism of your machine, and may begin to leave a mark on all the pullstuds, regardless of the tool change type : automatic or by hand; it's a gamble, is like a virus, that may spread acrros your entire toolholders; i would recomand using a gentle approach : i put the heavy tool on a piece of wood, and after that i gentle approach the spindle, from pulse-hand-wheel, and clamp it just right
    of course, bt-50 is heavier than\then\whatever bt-40, and so on
    i hope you find this useful / kindly
  1. How to Program a Pause for Manual Tool Change? HELP!
    By cnataliec in forum G-Code Programing
    Last Post: 07-04-2019, 12:30 AM
  2. HSK Style Tool Holder Manual Tool Change Spindles
    By tinmancarving in forum Spindles / VFD
    Last Post: 10-01-2018, 08:05 PM
  3. Change time delay in tool change program
    By bspear in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2018, 04:01 PM
  4. Manual Tool change under Mazatrol program
    By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-16-2018, 01:45 PM
  5. Replies: 2
    Last Post: 10-26-2011, 07:25 PM
