585,914 active members*
3,936 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas VF4ss Low high pressure coolant.
    Oct 2014
    15
    The high pressure pump is acting like its losing its prime. Any ideas why?
    Its about a month old and haven't even filled a 5 gallon bucket with chips yet.
    Thank you in advance.
    Sent from my SM-G935T using Tapatalk
    Mar 2010
    1852
    Re: Haas VF4ss Low high pressure coolant.
    Do you have any type of filter or screen on it?
    Oct 2014
    15
    Yes filters and screens are clean.
  1. High coolant pressure
    By alearner in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 12-12-2014, 11:24 AM
  2. High pressure coolant
    By Chispas in forum Okuma
    Last Post: 11-28-2012, 10:25 PM
  3. Is high pressure coolant necessary?
    By RMW in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-11-2011, 07:46 PM
  4. High Pressure Coolant
    By davek11 in forum GibbsCAM
    Last Post: 03-17-2011, 04:08 AM
  5. high-pressure coolant
    By 307startup in forum Mechanical Calculations/Engineering Design
    Last Post: 09-29-2007, 10:40 PM
