586,011 active members*
5,089 visitors online*
Page 3 of 3 123
Results 41 to 53 of 53
  1. #41
    Re: New version V2.3.4 released
    jwatte, you have a link for that granite block? I've searched on Tormach's website but I'm not finding it. I'd like to purchase one for my TTS stuff.
  2. #42
    I found it! I was a click or two away.
    https://www.tormach.com/store/index....13&portrelay=1
  3. #43
    Aug 2014
    257
    Quote Originally Posted by CL_MotoTech View Post
    Take a look here for some other ideas: Drilling the surface plate
    I did this & it has worked out well.
  4. #44
    Nov 2007
    2151
    Quote Originally Posted by jwatte View Post
    Tormach has a small surface plate (granite block) with a bored hole for the TTS tool holder.
    You put the tool holder in the hole, the flange sits on the plate. You use a height gage sitting on the plate to measure the tip of the tool, and punch that number into the tool table.
    For the machines like the Tormach, this is useful for two reasons:
    - it's cheaper than the electronic setter, and needs no calibration or maintenance (assuming your height gage is good)
    - the Tormach machines don't have particularly large work envelopes, so cluttering up the bed with a pre-installed setter (like you'll often see in Haas VFs) would remove useful area
    Yes, you can use an ETS on a Tormach, if those aren't problems for you. I think Tormach even sells one.
    I understand the tts system fully. I have the surface plate by tormach and over 50+ tts to measure in it
    The new MX mills have a bt30 taper and the block for tts will not work for off line measuring of tools. It would take a surface plate with a taper, and I just don't see those very often and reason for the question. Oh and the offshoot discussion about the g37 command in pp and the reason they are developing it for use with ets. Combine the function in your cam post will make it highly automated and very useful. Imho and experience .
  5. #45
    Dec 2015
    38
    I use the TTS JT1 chuck arbor as my tool 0 and all the tools are referenced off it using a vertex zero setter.It is relatively quick to use and by using the set z button I avoid writing the wrong length in by mistake.
  6. #46
    Jun 2014
    1780
    Quote Originally Posted by ally-g View Post
    I use a Z dial indicator as my tool 1, now I have it set to the height of my probe. I reset all my unused tool entries in the tool table to 9 inches so that if I call the wrong tool and nothing is in the height setting it doesnt crash the machine, I do this because at my age I screw up regularly and sometimes it gets expensive ha!!
    mike sr
  7. #47
    Nov 2012
    591
    @mountaindew I don't think you really need a taper; just a larger bored hole? (Or, for that matter, a larger vee block)
    If I had the space to spare, I would totally want an ETS, because it's a faster method when changing tools, and I do break or wear out tools with some frequency.
    But the bed just isn't big enough for that to be worth it, for me.
  8. #48
    Nov 2007
    2151
    I was thinking taper tools are held by stud, referenced by taper, and driven by dogs. I looked and tormach sells a height setter "non electronic" for their bt30 system .
    It looks like a decent method to set taper tools referenced to it including a hamier or other probe . More or less same system as tts with plate and height gauge but the spindle is used as the holder and setter as gauge , pp tool table would work the same. And no ets plugged in and setting on table.
    Surface plate and height gauge is kind of fiddly for setting tool heights. This strategy would also work with tts. And I like the idea of setting the numbers using the machines dro .
  9. #49
    Jun 2014
    1780
    I was thinking about a large straight hole in a granite block and use a couple of ground tool bits for the face surface of the BT 30 to sit on and that would clear the drive dogs, just a thought... Doesnt it indicate off the face surface rather than the taper?
    I think indicating off a taper could be a real can of worms.............
    mike sr
  10. #50
    Oct 2005
    1145
    Most tapered tooling references off teh taper and teh guage line. The only other precision point of reference is teh tool fork slot. All you need to do presetting is a simple 7/24 taper adaptor. IF yous guys had did a simple Google search based on BT30 prestter you would see how it works. The taper adapater holds teh tool in reference and everything else works just like teh TTS Version does.
    You can buy or simply build teh taper adapter. It has a 7/24 taper and there really is not a need for a guage line reference as long as teh hole is small enough to hold teh tool by teh taper only.
    Install teh master tool and set to ZERO then reference all tools from teh master tool. Very simple to do.
    Just a thought , (;-) TP
  11. #51
    Nov 2007
    2151
    Quote Originally Posted by vmax549 View Post
    7/24 taper adapter the method you use?
    I understand all these strategies, mostly learning how people use them. As I mentioned before the tool setter tormach sells with the bt30 system looks like a nice way to use the machine dro to set tool heights with tts also. I find surface plate offline tool height setting a little fiddly and would like to have another option or 2.
    Btw no such thing as simple google search lol
  12. #52
    Oct 2005
    1145
    There are dozens of ways to do tool setting . Setting the tool in teh machine is a good way to use teh precision of teh machine to set tools.
    (;-) TP
  13. #53
    Oct 2005
    1145
    HUM (;-) Simple Google search "BT30 presetter " BINGO, example and answer.
    (;-) TP
Page 3 of 3 123
  1. Version 2.0 released!!!
    By momus_cnc in forum Momus Design CNC plans
    Last Post: 06-16-2012, 05:07 PM
  2. VCarve Pro Version 4 Released
    By Tony Mac in forum Vectric
    Last Post: 09-01-2007, 04:14 PM
  3. NCPlot version 2 has been released
    By MetLHead in forum News Announcements
    Last Post: 03-01-2007, 05:21 AM
  4. VCarve Pro Version 3.1 Released
    Last Post: 08-20-2006, 12:35 PM
  5. RoboFac Version 0.0.5 Released
    By SimonArthur in forum OpenSource Software
    Last Post: 05-23-2005, 08:59 PM
