Hi There
Every thing was working fine before, but after some moving of my shop and not working with my CNC machine it is acting a little strange
In order to run my machining program my spindle does not run by Pushing the Cycle start Button (After pushing the button the axis move but spindle doesn't run) and in order to run my Cutting program at first I must start the spindle using the Spindle CW F5 Button and enter the RPM, then I push the CycleStart Button, and then it start to cut and behaves normally.
I use artcam to generate commands, and before I had no issues with these commands.
What could be wrong with my setup?
My machine is made of the followings:
• Two 4.5 N.m (637 OZ-In) NEMA 34 Step Motor for my Y Axis. (To be Exact the Leadshine Model No. 86HS45 Step Motor)
• One Of The same Motor for X and another for Z Axis.
• Y and X axis are rack and pinion with a 13 Pitch Pinion each @ 7 mm apart.
• The drivers are also LeadShine M880A
• My Board is the Typical Chinese made. The so called 5 axis Board.
• Spindle is a 3 Hp Single phase which I run it using a single to three Phase LS Inverter.
• The Structure is a Light 4”*4” (10 cm * 10 cm) Square Tube
• The Dimension of the Table is 2m*4m, So it is sort of Big but not so heavy since the thickness of Tube is only 2 or 3 mm.
• The Controller is Mach3 Version R3.041
Regards
Jhonansaro
