585,729 active members*
4,646 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > GRBL sends ERROR:33 when CHECKING generated GCode.
Results 1 to 6 of 6
    Mar 2011
    357
    I am running Fusion 360, UGS, GRBL(on an original Arduino UNO R3). I have POSTed many tool paths since building my machine and have never encountered this error.
    Fusion generated a 97000 line tool path. When I run UGS in check mode I get the error seen in the attached picture.
    Attachment 429156
    Have any of you encountered this and fixed it?
    Attached is the Fusion file if you care to look at how it is set up.
    The tool path giving me the error is called 2D pocket1 (2). All the others run fine.
    Aug 2009
    230
    Re: GRBL sends ERROR:33 when CHECKING generated GCode.
    That error is generated when Grbl can't figure out what the internal representation of the arc should be from the co-ordinates specified. Usually this is the result of specifying a center point that isn't actually in the center of the arc.
    As to why Fusion is generating something that Grbl doesn't like - I don't know; and I'm sitting in a restaurant right now so I can't try to debug it. One of these days I probably ought to put together a portable Grbl rig that I can just throw into my laptop bag, but for now all my machine tools are at home...
    Mar 2011
    357
    Anybody else??
    Please
    May 2004
    210
    So, it's something in the G-Code. I'd try to figure out the offending line, track it back to the specific tool path and then the specific feature in your model.
    By the way, if you have a spare arduino, you can hook it up, load grbl and debug from your dev machine so you don't have to run it on your mill/router.
    Mar 2011
    357
    UUGH This error is all over the carbide motion and x-carve boards with lots of different "resolutions". Was hoping to get more info here. I really don't know g-code but the error line is posted in the initial post.
    Mar 2011
    357
    I downloaded the latest post from the autodesk posts library and reposted this tool path but I have the same issue. I am a noob with g-code and dont think I have the skills to figure this out.
    Any help would be DEEPLY appreciated.
  1. PartKam gcode won't run on grbl Candle
    By dlatch in forum G-Code Programing
    Last Post: 04-09-2019, 08:45 PM
  2. GCode for GRBL based mini Pen Plotter
    By panoss in forum OpenSource Software
    Last Post: 01-18-2019, 10:05 PM
  3. Replies: 7
    Last Post: 06-11-2016, 09:23 PM
  4. Error 021 Fanuc with generated NC code from Edgecam
    By rookiemistake in forum Fanuc
    Last Post: 03-06-2015, 12:21 AM
  5. tool size concept- tool path generated vs gcode
    By kjl-pdx in forum Mach Mill
    Last Post: 03-12-2013, 07:25 AM
