585,996 active members*
4,572 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Spindle variation on cnv
    Some high end cnc lathes use a technique called "Spindle Speed Variation", once turned on it continiously varies the speed of the spindle up and down (example:+-50rpm) over a fixed period, say 2 seconds. The theory is that it prevents harmonic vibrations building up between the tool and the material which extends tool life, reduces chatter and improves surface finish.
    What is the general opinion on wether this would be of benifit on a milling machine as opposed to a lathe. Im working on an extension of the popular grbl firmware, where we have added an internal tachometer and adding this capabulity given the firmwear is now aware of the actual spindle rpm would be relativly simple.
    Thoughrs?
    Dec 2013
    5717
    Re: Spindle variation on cnv
    I have done this on a CNC mill by manually adjusting the VFD while cutting and it seems to help control chatter under some conditions. Might be worth a try.
    Jim Dawson
    Sandy, Oregon, USA
  1. Adding taper to spindle variation macro
    By EricBW in forum Parametric Programing
    Last Post: 01-19-2017, 12:47 AM
  2. X Y variation laser cut
    By toons666 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-12-2016, 02:45 AM
  3. Spindle Speed Variation Control
    By gunda in forum Okuma
    Last Post: 01-31-2012, 10:38 PM
  4. macro for spindle speed variation
    By lovetofish89 in forum Fanuc
    Last Post: 04-09-2010, 09:59 PM
  5. TL-1 SSV (spindle speed variation)
    By xyzcnc in forum Haas Lathes
    Last Post: 07-25-2007, 05:48 AM
