585,975 active members*
4,566 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > G54 Error - Flat End Mill offset?
    Question G54 Error - Flat End Mill offset?
    I'm new to cnc and I got an opportunity to use the machines a a brand new shop
    2 mills with Fanuc oi MF controllers
    I received code and it won't simulate on my manual guide I or other sims. It jumps back and forth and does not complete the code.
    also could someone give me generic tool data for a flat end mill
    heres some dimensions of the tool I received D.0625 z -.03 cr=0
    Also sorry to be a newb but what do those pertain to - obviously the tool offset data but how do I convert that to the geometry page.
    Thank You,
    O
    15362
    Re: G54 Error - Flat End Mill offset?
    Quote Originally Posted by fanucdiamond View Post
    Thank You,
    O
    You don't have to put anything in the tool offset page this is only active when you are using cutter comp G41 G42 if that is in your program then you need to add the tool diameter
    When you do a program using a Cam Program you set the tools you are going to use in the program once processed everything should be ready for the machine all that is needed in the machine is your work Offset and your Tool Z Offset the Geometry page can be setup for your tool number and tool diameter but not always needed
    Mactec54
  1. Offset crc error
    By Robert Sanders in forum Haas Mills
    Last Post: 02-23-2024, 09:17 PM
  2. 3D part offset error
    By Andre205th in forum Uncategorised WoodWorking Machines
    Last Post: 08-30-2018, 07:48 PM
  3. mini mill table not flat
    By chicotwo in forum Uncategorised MetalWorking Machines
    Last Post: 06-19-2008, 03:39 PM
  4. Flat Bed Camera to Mill conversion
    By jake292 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-10-2006, 11:21 PM
  5. CNC Mill Table not flat
    By MrMagooo in forum DNC Problems and Solutions
    Last Post: 01-03-2006, 12:01 PM
