584,842 active members*
4,506 visitors online*
Thread: Servo Choice
Results 1 to 7 of 7
    Feb 2019
    91
    Servo Choice
    hello just asking which servo is best for my z axis which weight around 50kg
    i got 3 choice the price is same since it used
    1KW Delta ECMA-EA1310SS 17 Bit Absolute <medium inertia
    1Kw Delta ECMA-E11310SS 20 Bit Incremental <medium inertia
    750W Delta ECMA-C1 20 bit Incremental
    24216
    Re: Servo Choice
    At 50Kg you may want to look at some kind of counter-balance.
    Al.
    Albert E.
    Feb 2019
    91
    Re: Servo Choice
    Al.
    i was thinking about it, my spindle got some kind of hook is it ok for me to just hok some kind of weight to that?
    Re: Servo Choice
    Quote Originally Posted by teamloks1 View Post
    Z axis motor should has brake.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Feb 2019
    91
    Re: Servo Choice
    Quote Originally Posted by cncmakers001 View Post
    all of this model have brake currently im thinking how to choose gas strut for this weight
    Dec 2015
    Re: Servo Choice
    Do not need gas strut. Any motor will be OK. For more smooth motion, a small lead or small motor with gearbox will be better.
    Aug 2009
    230
    Re: Servo Choice
    I'd consider a spring to take up some of the weight, though. By not having the servo constantly fighting that weight, it'll use less power and run cooler.
  1. Help with the choice of servo drive for servomotor
    By sigsig in forum Servo Motors / Drives
    Last Post: 03-11-2017, 07:02 PM
  2. Constant Torque Servo Choice and Control
    By wilcorp70 in forum Servo Motors / Drives
    Last Post: 05-15-2012, 06:57 PM
  3. CO2 right choice?
    By daem0n in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-08-2011, 05:07 PM
  4. Stepper or Servo? Best choice and best source...
    By BWay in forum DIY CNC Router Table Machines
    Last Post: 01-12-2009, 04:27 AM
  5. choice of diy servo driver package
    By GMS in forum Open Source Controller Boards
    Last Post: 10-04-2007, 03:27 AM
