585,676 active members*
4,542 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Best 4 Axis CNC Foam Router Routing 3D Polystyrene Shapes | CNC Foam Prototyping
Results 1 to 1 of 1
    Oct 2019
    10
    Working Videos:
    Advantage of EagleTec 4 Axis CNC Foam Router For 3d Polystyrene Shapes
    • The equipped spindle is a high torque & big power HQD automatic tool change spindle, with ISO30 tool holder. Can hold tools with a maximum diameter of 20mm. Spindle is 4 axis, can swing ±90°.
    • Z-axis stroke of 4 axis cnc foam router is up to 1000mm, and the load is relatively heavy. To ensure fast and accurate positioning, we designed dual pneumatic counter-balance for Z.
    Z axis is driven by Delta servo 1,300w motor with holding brake, transmission way is via precise ballscrew.
    • Also has a 4-axis rotary axis.
    Quick Details of 4 Axis CNC Foam Router for 3D Polystyrene Shapes
    • Working size 2000x3000mm (6.5x10 feet)
    • Z working size 1000mm
    • Rotary working size 1000x3000mm
    • HQD 9.0KW ATC spindle, air cooled (can swing ±90°)
    • Delta servo 1800w on X & Y, 1300w on Z
    • Linear guides 35mm
    • SYNTEC cnc controller (bus master)
    • Steel working table
    • Net weight 8,000KGS
    Best CNC Foam Router with 10+ Years Experiences
