Hi..
Click on picture to see full size.
(btw. how can i show the picture in full size in the message ?)
I want to make a cnc router frame.
With as big as travel as possible.
Problem is the frame should go through the door of my hobby room.
I came up with a other way to make the frame and linear bearing construction.
With the linear slider bar fixed to the bottom of the work table, instead of to the frame..
And the bearings to the frame of the cnc router, instead of to the work table.
After removing the work table the frame will be much smaller.
And fit through the door of my hobby room.
Which one is the best of these two ?
Both have the same travel lenght.
