Looking for parameter to change air during tool change being off
and
parameter to open up more memory
Prior to a recent upload thru rs232, causing machine to "lose its mind" We had to re-enter all the parameters. I was sure we had a copy of them, but couldnt locate, Got a copy or params from methods, which got us very close. Had to adjust 6036 for atc vs z limit.
What I have now, it machine thinks it only has ~8k bytes when previously it had ~26k, looking for what parameter to change to fix that.
Also
tool changer used to do a blast of air on tool removal, and another once it had cycled carosel to the next tool. Now its just blasting air while the carosel is cycling through tools. So a change from t1 to t10, is just constant air blowing.
Ideas? thanks!
