585,996 active members*
4,472 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > centurion 4 IV periodically freaks out
    Dec 2007
    126
    Runs fine, then other times just freezes. When it freaks out, is typically hitting handwheel or jog, and the x and y axis jump, and it e-stops. Maight come back on fine after that, might just jump again.
    Seems to be worse after sitting e-stopped or not, for 30-60 minutes. Ironically today, it has sat now for a few hours, and seems happy, ready to run, no jumping axis's.
    Pulled apart, nd cleaned, sprayed with contact cleaner every single plug I can find in the back panel. Maybe changes, other times doesnt seem to.
    Sometimes on turning main power on, the controller wont come on at all, and have to turn off and back on to even be able to reset drives and have a screen.
    Id love any ideas on what is likely/possibly the root cause
    Jul 2010
    548
    Re: centurion 4 IV periodically freaks out
    Hi Brian, might need to check the power supply voltages.
    I have C4 parts
    give me a call.
    sportybob
    952-288-6340
  1. Taking the chucks off your rotary tables periodically and deep cleaning.
    By pickled in forum Tormach Personal CNC Mill
    Last Post: 06-05-2015, 04:13 AM
  2. Laser periodically decides to 'skip' a hole
    By ghyman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-17-2012, 10:07 PM
  3. Inventorcam periodically closes and open parts
    By glovebox20 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-04-2012, 03:15 PM
  4. Centurion 5 vs. Centurion 6 and validation codes
    By Turbo VW in forum Milltronics
    Last Post: 02-11-2007, 09:35 PM
  5. I'm Considering a Centurion 1
    By TZ250 in forum Milltronics
    Last Post: 09-07-2006, 08:30 PM
