Originally Posted by
Zorbit
Someone better tell Sandvik they got it all wrong.
Iscar too. https://www.iscar.com/Catalogs/publication-2019/machining_titanium_05_2019.pdf
There a widespread belief that titanium is like austenitic stainless steel in terms of its machinability. This may be true when relating to commercially pure titanium and also, with some assumption, ?- or even ?-?-alloys; however, it is fundamentally wrong with respect to the treated ?- and near-?- alloys.
In general, titanium alloys (which we will refer to as titanium and specify their composition, grade and properties separately where necessary) are hard-to-machine materials and their machinability depends on various factors: chemical composition, hardness, method of treatment. The main difficulties in cutting titanium are the following: • Intensive heat generation leads to excessive adhesive wear of cutting edge. • Low heat conductivity results in poor heat transfer and slowing heat dissipation down. Therefore, cutting edge experiences considerable thermal loading. • “Springiness” of titanium due to low modulus of elasticity contributes to vibrations and worsens machining accuracy and surface finish. The mentioned factors significantly reduce tool life and affect performance. The averaged data in Table 2 allows estimating machinability of titanium compared with other groups of basic engineering materials. Table 2 - Machinability Of Titanium Vs. Typical Engineering Materials (Averaged Data)
And Kennametal,
https://www.kennametal.com/kr/ko/industries/aerospace-old/machining-titanium.html
And Makino, who have a range of "T Series" machines designed specifically for cutting titanium - 53 gallon per minute through spindle coolant pump ! I guess they haven't heard of olive oil ;-)
"Titanium Alloy Ti 6Al-4V If you are reading this white paper, it’s likely that you have either heard about or experienced first-hand the challenges associated with machining titanium. You probably know all too well that its unique characteristics combine to create a perfect storm of machining challenges!
When machinists refer to issues with titanium, they are often actually referring to a specific titanium alloy called Ti 6Al-4V (also known as “Grade 5” titanium). Ti 6Al-4V is the most common titanium alloy; it makes up about 50% of all global titanium consumption."
