585,715 active members*
4,622 visitors online*
    Aug 2005
    176
    PWM Pulse Width Modular for Laser
    Does Centroid controller had a PWM output for running a laser?
    Rob
    Feb 2008
    280
    Re: PWM Pulse Width Modular for Laser
    No.
    There is a 0-10V analog voltage output, normally used for spindle speed control, which can be used for other purposes on a machine with no spindle.
    If your laser requires PWM, then you could probably assemble some type of interface circuit (maybe using an Arduino type board?) that will read the analog voltage and output a PWM sequence.
    Feb 2008
    280
    Aug 2005
    176
    Quote Originally Posted by cncsnw View Post
    No.
    That’s encouraging. The PWM on Centroid forum might be the trick.
    I surprised Centroid hasn’t come up with this.
    Rob
    Aug 2018
    621
    Quote Originally Posted by artracing View Post
    Rob
    If you are talking about the Acorn it has a 0-10v analog on the board.
  1. Pulse width for DM856
    By chris86x in forum Leadshine
    Last Post: 07-27-2015, 02:04 PM
  2. Feedrate and Step Pulse Width
    By coykiesaol in forum FlashCut CNC
    Last Post: 09-19-2010, 05:03 AM
  3. Mach Step And Dir Pulse Width
    By Brenck in forum Mach Mill
    Last Post: 10-17-2009, 06:56 PM
  4. Understanding Pulse width, rate etc
    By DaveDoesIT in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2008, 04:04 PM
  5. Pulse Width
    By coop2005 in forum Automation Technology Products
    Last Post: 09-16-2008, 07:10 PM
