585,722 active members*
4,433 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Syil X5 Speedmaster Z axis limit switch
Results 1 to 3 of 3
    I have recently acquired a used Syil X5 speedmaster. I've got it working, mostly, Utilizing Mach3 with a smoothstepper. I have set all the home pins and dirs up in Mach3 and when I do a 'Reference All Home' the x and y home perfect but the z axis never moves.
    I'd like to know where the z axis limit switch is located so I can check, e.g. clean, voltage check and etc. I've searched high and low on the web but nothing show the z axis. Syil is not much help either.
    FYI in Mach3 the outline around the x and y zero buttons are green while the z zero show red. My thinking that Mach3 is not getting a signal from the z axis limit switch, if there is even one.
    Quote Originally Posted by atomic928 View Post
    OK solved it, thanks for everyones help and input
    Jun 2007
    3757
    Re: Syil X5 Speedmaster Z axis limit switch
    I believe you are getting a spurious spike on z axis making mach3 say it is homed.
    Symptom is that z axis ends up green.
    My SX3 gets spikes on z sometimes due to dust on z slide causing exactly the same problem.
    For me, if the home position is important, a blast with compressed air fixes it.
    I ALWAYS home machine at turn on to ensure soft limits always work,
    but doing mostly manual work it only means I can't get z axis high enough.
    The cutter stops it in -z direction.
    So I then just re-home z from the diagnostics page.
    When homing, my mach3 ALWAYS turns on soft limits.
    I achieved this using screen.exe (mach3 screen designer) by adding 'turn on soft limits' to the end of each screen button that does homing.
  1. New Syil X5 Speedmaster from Charter Oak
    By Bob La Londe in forum Charter Oak Automation Support Forum
    Last Post: 04-05-2018, 04:16 PM
  2. Syil X5 Z axis limit switch location
    By AussiHorologist in forum Syil Products
    Last Post: 08-14-2014, 06:55 AM
  3. Syil x4 speedmaster
    By mkozan in forum Syil Products
    Last Post: 05-26-2012, 12:01 AM
  4. syil xp5 trigger limit switch
    By Vik in forum Syil Products
    Last Post: 10-29-2010, 07:05 AM
  5. Syil X4 speedmaster
    By syil canada in forum Videos
    Last Post: 09-28-2009, 12:34 AM
