585,917 active members*
3,481 visitors online*
IndustryArena Forum > CAD Software > Autodesk > UNwrap OD surface of ppe
    May 2006
    265
    Ive got a solid of a pipe with differents cut, that I would want to get the OD surface "unwrapped". Is this possible on acad or must I use somekind of sheet program? COuld someone help me if I provide the solid?
    AutoCAD won't unwrap it for you, but you could draw an unwrapped version if you you're good.
    This might be of interest, but may not be much help.
    http://www.tamasoft.co.jp/pepakura-en/
    May 2006
    265
    Any other cad that can do this?
    Jun 2006
    12
    solid works will do it, in most cases. aslong as you know where the split line and diameter of part.
    May 2005
    1810
    Inventor will unwrap also.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
  1. Countersunk Surface
    By Rally in forum Mastercam
    Last Post: 05-25-2007, 08:16 PM
  2. unwrap cylinder to engrave on o/d
    By Capt Crunch in forum Mastercam
    Last Post: 04-23-2007, 01:18 AM
  3. MDT 6 Surface Cut
    By djzepp in forum Autodesk
    Last Post: 04-11-2007, 04:56 AM
  4. could you check my surface.
    By corrie in forum Rhino 3D
    Last Post: 04-09-2006, 02:35 AM
  5. 3D wireframe surface
    By JW Peters in forum Autodesk
    Last Post: 05-10-2005, 01:23 AM
