585,898 active members*
5,335 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > NEED HELP WIRING BREAKOUT BOARD
    Oct 2019
    Talking NEED HELP WIRING BREAKOUT BOARD
    Hello to the group, I'am a retired printer who's not ready to sit & ponder so i built myself a 40x36 cnc router using (3) hybrid steppers, ball-screws and Mach3. with that said, when building my control box i discovered a very important fact, i know nothing about this! Thru Amazon i purchased an off market break-out board. it's from China and has Chinese depictions . i really need help with making connections to my motors without burning nothing up. CAN YOU GUYS HELP ME?
    It's call Keenso DIY CNC 6axis Mach3 Motion Controller on the Amazon web-site. I took a picture of the board and will attempt to post it.
    thanks in adv.
    Jan 2009
    Re: NEED HELP WIRING BREAKOUT BOARD
    Quote Originally Posted by nugie View Post
    thanks in adv.
    Hi I am a new bee and bought a 3 axis break out board from amazon and fell in the same hole
    It will not drive motors as you can see there are no heat sinks and power devices. Its just a driver board for a stepper board and motor one for each axis!
    Dont know why you would need 6 axis but I bought a 3 axis off ebay . Computer in and hook 3 motors out and it works fine
    just get the proper paperwork for the board. JAPAN will sell anything you have to figure out LOL
    PS buy the parallel port board not the USB
    1222
    The board looks like a number of other similar cheap boards and can almost certainly be made to work.It won't run steppers directly and has to be connected to a stepper driver which handle the sending of the operating current to the steppers at their rated voltage.As for 6 axes, if you have a gantry of any size it is common to run a stepper at each side and the spare pair will be useful if you decide to undertake any work requiring a fourth or fifth axis. It looks like you need a 5V power supply to operate the board and they are quite cheap, unlike the stepper drivers that are needed, and a bit of searching will turn up several wiring diagrams that ought to guide any newbie a bit further.
    Mar 2007
    2083
    the breakout board can only control 6 stepper drivers
    if you don't want to use the 3 relays or need the analogue control output to control the spindle speed
    to control the 3 relays and spindle speed you will only have 8 outputs available to control 4 stepper drivers
    you will either need to connect the board to a PC's parallel printer port or a motion controller that replicates a printer port
    what do you need to control -
    how many axis and how many relays , and do you need computer controll of the spindle speed ?
    did you get a manual with the board or a link to a PDF manual you can post ?
    as its not clear from the photo which pins can control the relays or use for the PWM to analogue speed control
    John
  1. Breakout Board Wiring
    By Pmccourt in forum DIY CNC Router Table Machines
    Last Post: 06-09-2019, 06:12 PM
  2. Need help wiring VFD to UB1 breakout board
    By hl68fx in forum Spindles / VFD
    Last Post: 03-01-2019, 12:43 PM
  3. Need wiring of this Breakout board and ID
    By Barefootboy4 in forum Automation Technology Products
    Last Post: 12-27-2017, 10:49 PM
  4. wiring without Breakout Board
    By tpsimer in forum DIY CNC Router Table Machines
    Last Post: 02-16-2017, 09:02 PM
  5. Breakout board wiring help!
    By frostyshoal in forum DIY CNC Router Table Machines
    Last Post: 05-08-2013, 03:05 AM
