584,865 active members*
4,846 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Leveling stock using 4th axis and probe
Results 1 to 10 of 10
    Oct 2009
    51
    Can anyone help with any "simple" methods of leveling stock in Y axis terms, that is chucked in the A axis ...... using touch probe outputs/findings ?? Perhaps a better way to put it is - how do you relate -Y axis touch probe Z output and a +Y axis touch probe Z output ..... so you can turn that into how many degrees to A axis needs to travel so -Y and +Y Z level is equal ??
    Oct 2009
    51
    Re: Leveling stock using 4th axis and probe
    I have re-read the above post and think it may be a confusing/overly complicated way of explaining the problem and I'm relatively new to the CNC game .... so I'll try another way.
    I am trying to tram stock (an existing part) that is mounted to the A axis .... using outputs from a touch probe. I need to incorporate this into a program so the machine can probe the parts Z height and then tram the part via the A axis.
    I have tried to do this manually by jogging an equal distance either side of Y 0.0 and writing down the Z heights of each side .... then splitting the difference between the Z heights .... jogging the probe up/down to that point .... then jogging the A axis till it touches.
    That "manual" method gets the tram close .... but there is still quite a difference when repeating the same jog/probing process to check it is trammed. I think this is most likely caused by parts height above the A axis rotational center (around 9 inches) which would mean the surface I'm trying to tram, is moving in both Y and Z terms when the A axis is moved ??
    There must be a method to calculating the A axis rotation required .... but I can't dig up any knowledge/routines to making it work.
    Any help appreiated
    Nov 2012
    1267
    Wouldn't that be arctan(Zdiff/Ydist)? Ydist is the distance between the two probing points (centered at Y=0), Zdiff is the difference between the probe readings in those points.
    Oct 2009
    51
    It been a LONG time since I was at school but doing a search on arctan I think you might be on the right track. Looking at a definition of what arctan is, I am probably getting the error as I'm not doing the first touch at Y 0.0 ??
    The method I was trying was equal distance from Y 0.0 ... e.g Y -2.0 & Y 2.0 . Does that make sense to anyone ?
    Nov 2012
    1267
    Quote Originally Posted by Cfin View Post
    The arc tangent formula should be correct for any two points, assuming the stock is flat. For instance, if your probe touches at (Y=3, Z=-0.07) and (Y=5, Z=-0.05), then the stock is tilted
    arctan ((-0.05-(-0.07)/(5-3)) = arctan (0.02/2) = 0.57 degrees. That's the amount you must rotate the A axis to align the stock with the XY plane.
    If my math is wrong (which is entirely possible), please correct me.
    Oct 2009
    51
    Ok, I can understand that and think I have my head around it now. This is probably a dumb question but I'll ask it anyway .... I assume for this to work correctly Z0 would need to be set to the A axis center line height?
    Nov 2012
    1267
    No, Z0 does not matter. The formula will give you the same answer no matter where your Z0 is.
    Oct 2009
    51
    Yes that makes sense to me now. Thank you very much for your help !!
    Oct 2019
    I recommend looking at website if you are interested in a new type of game. Where to find out all the intricacies of games like this.
    Mar 2008
    683
    Use the "find center point" probe option in the setup menu. It does the math for you. As for automating it to a touch probe with a fadal controller I have no idea.
  1. Hardinge out of stock on X axis bearings - what now?
    By lrgoodger in forum Bridgeport / Hardinge Mills
    Last Post: 12-14-2015, 08:23 PM
  2. Probe to find center of stock???
    By mioduz in forum Mach Software (ArtSoft software)
    Last Post: 08-18-2013, 05:48 AM
  3. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
  4. Auto align B-axis (rotary axis) using probe
    By pwilson101 in forum Parametric Programing
    Last Post: 02-06-2012, 02:53 AM
  5. 4th axis tail stock
    By OptionCNC in forum Uncategorised MetalWorking Machines
    Last Post: 08-22-2011, 04:58 PM
