585,719 active members*
4,415 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Millac 800VH - 15818 "APC A position not complete".
    Oct 2019
    Below is a small description of the problem:
    The machine model is Okuma Millac 800VH
    The equipment failure is that when you want to change pallet M60 and automatic does not perform the sequence and in Manual mode, it does not advance to sequence and shows the diagnostic 15818 "APC A position not complete".
    In the APC sequence parameters it allows us to advance to stage 3. In number 4 (where the pallet goes up) the UP pallet output does not activate.
    Note 1: A sequence step does not execute the movement of the axes to home.
    Note 2: The original fault sent a Stroke over end alarm ¨ which was reset. No axis was moved or new origin was set.
    Jun 2015
    4154
    Re: Okuma Millac 800VH - 15818 "APC A position not complete".
    hi, far as i see, you can't reach the home, and there was an error about over stroke; this happens when the encoder slips, there is be a friction part, but also there may be other causes ... i would verify that the phisical travels and origins are where they should be, and after that the alignment, in respect to apc & atc
    what axis caused the over stroke, and why ? kindly
    Oct 2019
    Quote Originally Posted by deadlykitten View Post
    I am trying to find this information out, thank you for the response!
    Dec 2008
    3109
    I have had issues with APC no completing the cycle
    .... Rapid override set to zero
    .... spindle toolclamp in open condition ( or in-cycle )
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. Okuma Millac 800VH Parts Manual
    By Ososa in forum Machinery Manuals / Brochures
    Last Post: 04-13-2017, 08:04 AM
  3. Replies: 1
    Last Post: 09-18-2014, 09:57 PM
  4. Okuma Millac 550H Tool Magazine position error
    By HappyFingers in forum Okuma
    Last Post: 01-13-2014, 08:19 PM
  5. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
